Question: metering gauge for trailer battery
matthewp
Combat Truck Monkey
Folks,
Would there be a value in putting a voltage metering gauge on my trailer battery? My concern is with the power consumption of the gauge itself.
4x4junkie
Could always put a switch or something inline with the gauge wire so you can turn it off when you don't need it.
If it has an electronic LCD readout (or is an unlit analog gauge), I wouldn't think it would draw any appreciable amount of power though.
G35Vortec454
The digital volt/amp panels I use use < 0.050A which is very low consumption especially if the battery is connected to solar panels.
Rbertalotto
Volts won't tell you too much. better to be watching the amp draw from the battery..........
http://www.amazon.com/dp/B00CJ5NYV6/ref=pe_385040_30332200_pe_309540_26725410_item
DROK 0-100V/50A Digital DC Panel Volt Amps Tester Meter VA 2in1 Red LED Display+Shunt
Price: $18.01
Note: Free shipping when purchased from DROK. Not eligible for Amazon Prime.
Only 6 left in stock.
Ships from and sold by DROK.
Operating voltage:DC 4.5 ~ 30V
Measure voltage: DC 0 ~ 100V
Measure current:DC 50A (require external shunt)
Display: three 0.28" LED digital tube
Display color: Red
JIMBO
:sombrero: Mines a simple one that gives the voltage and charge status, on a switched circuit !
:costumed-smiley-007:wings: JIMBO
G35Vortec454
And if you get a digital display, get one that has polarity display that does both pos. and neg. readings (charge/discharge).
G35Vortec454
What are you using to determine the "charge status"? The only absolute way I know is taking specific gravity of the battery electolyte. My meter readings are just telltales of the present situation but they're convenient.
zhukoveli
