Lucky 8’s Project P38
EricTyrrell
Expo God
Great story. For early D1 there is a immobilization bypass harness sold by AB. For late D1 the entire security system can be disabled with a Faultmate/Hawkeye/T4/Autologic system. Is there anything like that for the P38?
spikemd
Looks like I need to get my BECM to Scotty at BECMdoctor.com before I head to Mexico. I like the idea of a spare BECM as well. Those door actuators are a common issue. Not sure how to avoid it other than replacing it now before it causes trouble.
P38 looks great though.
R-Overland
Those BeCM are a lot more rugged, than people asume. Got it wet... Dry it ... put it back in... done.
If it ain't broke, then don't try to fix it.
ZG
Busy Fly Fishing
That truck took an absolute beating at VOT and made it out alive. Justin took it up to the top of the camping hill several times, I wouldn't have gone up once unless necessary.
Aegis
K9 Handler
Any word or movement on The Rhino? Been watching this thread religiously -- it's the one thing keeping the P38 in my mind as a viable option! :)
Fivespddisco
Supporting Sponsor
Project update : Traction action
The " VOT " Vermont Overland Trophy really prompted us to add a traction aid. We could've went with a bunch of options but we decided to go with the new Ashcroft ABT. The ABT is a limited slip diff using six helical gears to distribute power. When compared to a true track the Ashcroft unit is far superior in power distribution and build quality.
I can hear some of you complaining already. Yes we could've easily dropped in a locker but that would not have given us any real world experience with the ABT. I really wanted to see how the ABT did with the P38 second-generation traction control throughout the VOT
With the rear differential out of the truck we took it to the secret layer of lucky8's diff Jedi. It is rumored that he repaired an LT230 by only using his feet. I don't know if it's true but when I showed up he was wearing his shoes on his hands. Here's a look at the Black arts involve in upgrading the carrier.
Checking the backlash on the ringing pinion before dismantle.
Out with the carrier
The ABT unit ready to take the place of the week factory carrier.
If you ever give this a go on your own I cannot convey enough how important it is to use Loctite on the ring bolts.
It is so important it deserves a second picture
An interesting bit about the P38 diff. You can use the same carriers from a D1 But you need a spacer ring to compensate for the difference in thickness.
Just a few more finishing touches left.
With all the extra weight we planned on carrying it was not worth betting on stock axles to get the job done.
It was time for a set of Ashcroft heavy duties!
And yes they are ABS compatible.
The ABT did fantastic for us at VOT. Aside from a little noise during low traction situations you would not know it was in the truck.
L8 VOT Team
The take away from this adventure is the ABT provides an incredible amount of traction when combined with the ABS system.
Poser pic courtesy of Amy
OOOh
I
almost
forgot
Snorkel V2.1
Stewart_RR
My compliments on your ride Justin!
I´m a friend of palacosfr also with a p38 Range in Argentina but diesel. Thanks to him I followed part of your progress almost from the beginning. I was having some problems with my fully rebuild engine and radiator and didn't have the esprit to write before.
Very promising indeed that snorkel!
and I´m very interested in you expanding on your choice between ascroft lsd and the true track, also a KAM lsd differential that its related with terrafirma (??) has come to my attention and I think it is an interesting alternative.
Also compliments to Amy. And your writing, I have had a lot of fun reading the entire post. keep up the good work!
Aegis
K9 Handler
Awesome!
I've been wondering how the Ashcroft will hold-up, glad to see someone document putting it through it's paces!
... And, as always, DEFINITELY can't wait to see the end-result/finished offering for a P38 snorkel! Would love to actually have a production model available :D
mcapinha
Hi Justin. Great thread.
What are your thoughts about normal everyday road use for a P38 fitted with an ABT?
I remember reading about Kaiser diffs and everyone mentioned that they could become very noisy on tight turns on tarmac (like parking maneuvers).
Sent from my Nexus 4 using Tapatalk 4
Aegis
K9 Handler
A thought/question/hope:
Will the snorkel be available for commercial production, or is it a one-off for the L8 rig? :)
Fivespddisco
Supporting Sponsor
Thank you for the kind words my friend.
We could've also used the KAM differential. But I needed some real world experience with the Ashcroft ABT.
iStan814
