buyrovers
For sale is my 2002 Land Rover Range Rover Westminster. Since this is the Westminster edition it's one of 300 built and is equipped with black exterior paint on black leather that's special to this edition and is also covering the doors, lower dash, and all of the shifters. This vehicle also features the special black piano wood trim and has all the standard options like navigation and heated seats. The truck has covered 171k and has a few dings but overall looks great with shiny paint, great leather and carpet, perfect headliner, etc. A complete engine rebuild, all service done, heater core and o rings done, this truck drives great and doesn't leak a bit of oil.
A great deal of money has been spent on this truck which is listed below. Most everything done is in like new condition.
Maintenance and Repair:
-replacement long block
-new head gaskets
-arp studs
-rebuilt and pressure tested heads
- new top end engine seals
-battery 2013
-new water pump 2013
-new alternator 2012
-new muffler 2012
-new power steering pump 2012
-radiator 2011
-cooling hoses 2012
-Feb 13: diff fluids, trans fluid and filter, power steering, coolant flush, transfer case fluid, u joints, o2 sensors, MAF, cabin filter
Modifications:
- safety devices roof rack
-terra firma rock sliders with tree bars
-rock rover winch bumper
-10k super winch
-sub upgrade (currently not working for some reason)
-Goodyear duratracs 275/65/18. LIke new!!
-ome coil conversion with 764 front and 781 rear springs
-nitro charged ome shocks
-jeep disconnect sway bar links
-extended brake lines
-dba brake upgrade
-double Cardon front drive shaft
-LED spots and floods
-LED rear backup light
-hella 4k front lights with hardcovers (these are the expensive metal ones)
-highlift jack mounted on roof rack
As you can see this truck has had a great deal of money spent and it really is one of the nicest and most built range rovers in the US. As mentioned above the trucks factory sub has new speakers but currently isn't working and I haven't gotten around to doing a camber correction on the front so it could use that to make it drive more similar to stock, not an expensive job.
MORE PICS!
http://m292.photobucket.com/albums/buyrovers/02 Range Rover Westminster/
Charlottesville, VA
Asking $7500
-new head gaskets
-arp studs
-battery 2013
-new muffler 2012
-radiator 2011
-cooling hoses 2012
Modifications:
-10k super winch
-dba brake upgrade
MORE PICS!
Asking $7500
