Bumper carrier and still be able to tow a trailer.
rebar
Is there a motorcycle carrier where you still have use of your trailer hitch for towing? Maybe in the front to leave the rear receiver alone?
This will be needed for my 95 E350 on 35" tires and I'm solo.
Thanks!
Kyron
check joehauler.com .... I'm pretty sure they sell one set up like that.
I know you realize that the towing capacity is going to be reduced.....
rebar
Im not finding the rear mount where you can still tow. You cant mount your hitch ball on the carrier.
I did see the front mount though. Loading and unloading would be sketchy alone though.
rebar
Thanks again.
After I down size my trailer, one of those double hitch's might work. I'm envisioning a hydraulic dirtbike lift on the top receiver. Then once the motorcycle is lifted, you could hook up a small trailer. Trick would be the motorcycle lift, as it would have to move the motorcycle up and out of the way of the trailer tongue.
image search.. interesting
gp01
