Does ARB make front differential cover Gen 2 Monty
rajin cajun
Greetings!
Does anyone know if ARB sells a front differential cover for the 1994 Montero 3.5 SR? Thanks in advance.
Cheers,
rajin cajun
Follow up from ARB
I e-mailed ARB and received a swift reply. Unfortunately, they do not make diff covers for our Montys. Only Dana axles..........FYI
Good day!
rajin cajun
Faith in factory spec
Since the Gen2 is over built like a tank, both diffs are very well protected....
Many Blessings!!!!11
off-roader
Yeah, I was gonna mention that our rear diff is a 3rd member design so the differential is actually attached to the cover unlike the Dana 30-60 diff's where the differential carrier assembly isn't.. This means the cover has to be much stronger than the simpler Dana covers.
gp01
