I have read through many threads on this, and other, websites about flexible flatbed design.
Doug has been a big help too.
Now I am about to start bolting mounts to the frame of my cab/chassis F450, with 9' frame rails going out behind the cab. I am going with the Aussie/ozzie style, see picture of an M35's mounts to give a rough idea.
The trouble is there are only 4 good points on the frame to attached the angle iron for the mounts. These spots are essentially at the corners and in my picture below you can see the 2x6 chunks standing on end to indicate those spots. There are no clearance issues and pre-existing holes in the frame for these locations.
Where there is a 2x6 chunk on it's side, I could put a mount but only on the passenger side, the driver side has the emergency brake mechanism there.
Where you see the tape measure laying across, I could add a cross member and a single spring that is centered lengthwise, just over the diff.
There is no room to place mounts above the leaf springs, there is possible room within the forward mount for the leaf spring. The drawback here is I am looking at using a 6" or 8" spring and the 6 might not even clear there.
Other options would be to just use the four corners but with 2 springs at each corner, or try to add mounts that are tight to the inside of the frame.
Any thoughts or advice would be great. I would like to have more than 4 mounting points, there will be a camper going on the flatbed and I would feel better about a tall load having more points.
