More Tests, Conjectures,  4 [apparent] options
I performed four tests:
a)  I verified that the Actuator delivers a max of 18 psi boost when climbing a modest local hill;
b) I re-verified that if I get an overboost condition: up to 23-24 psi on my gauge, then a “Check Engine” fault light on the dash, and a diagnostic code #54 recorded in ECU memory.
c) on the possibility [hope springs eternal] that the Actuator rod was adjustable, I disconnected the arm from the waste gate valve pin, I measured the length of the arm, I rotated the arm both clockwise and anticlockwise measuring again in each position [no difference detected]; reconnected everything and drove my test hill with the arm still rotated one turn clockwise [to see if there was a change in boost]; my gauge showed the same old 18 psi max
d) I drove out to a longer steeper hill several miles away. On the way out there I  started throwing codes on flat stretches of highway as I was accelerating only enough to reach and hold highway speeds. Each time I could reset by ignition-off and then ignition-on again. I got 5-6 ‘limp mode' events in 7-8 miles.
As I see it, I have 4 options at this point:
— Live with 18 psi boost; it hasn't been all bad so far.
— Install another Actuator if I can get Mitsu to provide one under warranty.
— Purchase a commercial adjustable boost compensator and run its plumbing up to the cab.
— Trial and error my way to a fixed, in-line, no-moving-parts device that gets me to 22 psi under most conditions and does not cause overboost fault codes.
The first option is getting more and more acceptable; realistically, I can go anywhere I want ,I just get there a few seconds to minutes later than I might if I had lots more acceleration and hill-climbing power. The engine is completely reliable and that is more important than a few seconds, frankly.
