Unofficial Fuso Host Outback Camper Review (both the original & new triple slide-out)
mog
Kodiak Buckaroo
Lets get the disclaimer out of the way.
This is an UNOFFICAL review. I’m not a professional like Scott or any of the other Expo members who do these review routinely This was a last minute “hey can we stop by” visit, so nothing was prepared (aka: no dog & pony show). And while Randall say it was fine to give specs, prices, etc, I WAS NOT taking notes, so I’m sure some of my numbers will be OFF. So please don’t quote me, this is just a man-on-the-street review.
I when up to Bend Oregon last week to help John Rhetts with his Uber-Fuso (one of two 4x4 Fuso FMs), see his awesome rig and learn many outstanding build and system ideas from him.
We took a trip over to EarthCruiser and Host Campers who are based in Bend Oregon. No EarthCruisers were to be found, but Randall Pozzi the General Manager with Host Campers gave us a great tour of Host’s build facility. Also access to his top secret files on his computer and the in camper experiences with both the Outback 1 and ‘you can order it now’ Outback 2 campers. Also I was able to have a ‘in-town’ test drive of a Outback 1 mounted on a ready to go Fuso FG (owned by EarthCruiser) in Bend.
First a huge thanks to Randall. He dropped everything and spent over 3 hours with John and I. He knew neither of us were in the market to buy a Host camper at this time (we drove over in John’s Uber-Fuso), but none the less treated us as if we were signing a contract for 10 units. An indication of what I expect is great before and after customer service from Host Campers.
If you have followed posts on the Expo Portal here about the Host's Outback camper you will know the Outback 1 is a single partial side-out, rear door, fixed roof camper, mount to the Mitsubishi Fuso (they will mount to a 2x4 FE, or 4x4 FG) truck. This is the camper I drove.
But I want to get right to the new Outback 2 (this is the one I want). The Outback 2 has 3 slide-outs! Two full length (yes both sides slide-out the full length of the camper) and a rear slide-out. One word WOW ! I joked with Randall and John that if you had blindfolded me and brought me into the Outback 2 without seeing the outside, I would be describing to the FBI that my kidnappers held me in a Class A motorhome. One side slides out 20 inches, and the other side slides out 22 inches. Add that to the 84” the camper is closed and you have a whopping 126” width when in camping mode (don’t forget that disclaimer about,). Very very impressive. I’ll let Randall post the floor plan as all I have is a printed version of that. BTW, it has a side entrance door. Now I know you wondering, will those slide-outs hold up off-road. Hey, for some reason Randall would not let me have EarthCruiser’s truck and camper for 3 weeks for me to test this out, but both John and I were very impressed with the slide-out tracks. They were super beefy to say the least, with a great design. The rollers are completely captured in the tracks, so there is 100% no way the tracks, roller etc can part ways, or become misaligned. An outstanding design. The gear drive is all metal, no plastic and is huge. Again, I’m no engineer, but my man-on-the-street impression is you would have to do something stupid to mess this system up. All the slide-outs have triple seals. A rubber ‘flapper’ seal on the outside, another rubber ‘flapper’ seal on the inside and a rubber bulb seal on the outside. In addition standard fabric ‘awnings’ protect the slide-out tops from rain, leaves, snow etc.
Build of the Outback 1 and 2 campers. These are built in-house at Host along with campers for standard pick-up trucks. The walls are aluminum square tubing 100% welded. They are hand welded on jigs (no robots) and the welds are beautiful, with great penetration and pattern. Another impressive thing is that all the opening in the walls (windows) are 100% framed with the same wall tubing. Top, bottom, sides and even to the extent that they weld curved aluminum flat stock to follow the curves of the corners were the widows will be installed. A great attend to detail and I’m sure makes for a strong frame. I believe the side wall tubing is ¾” by 1” or 1”.5 inch square tubing. Randall pointed out that the Host campers for the Fuso get huge and thick floor tubing (I think 1.5” x 3.0” with 1/8” or 1/4” wall thickness, on 12” centers).
Once the frame is constructed, the outer layer of FRP (Fiberglass Reinforced Plastic) that comes already laminated to 1/8” ply is glued to the frame. Styrofoam insulation is inserted into all the opening, glues is applied, the inner wall is attached and the whole wall going into a vacuum press to bond everything together, under vacuum. Randall pointed out that all their material come in to the facilty ‘full size’, so nothing is pieced together, were seams might show or effect strength. It was impressive to see a 20 foot long by 8 foot wide sheet of plywood (I’m betting they don’t pick those up at Home Depot).
The layout is nice. When closed (both the Outback 1 and Outback 2) the bed up front is 100% useable and is accessible from the cab via a nice sized crawl through. The camper can be opened and closed from either a switch at the rear door OR from the bed area. So say it is pouring rain outside or the zombie apocalypse happen while you were asleep, you can simple crawl out of bed into the cab, hit the ‘close switch’ and drive off, not needing to go outside to operate any switches or flip any latches. When closed the area other then the bed is all together, aka: maximum use of space or "you are not getting in there". It has been mentioned in prior posts, wondering if the back would be useable closed for a quick lunch stop, use the toilet, etc, the answer is no. But I would guess it takes less then 10-20 seconds (the Outback 1 and 2 seem to deploy in the same amount of time) to deploy the side(s), so I don’t see a downside to that. I would much rather have the space used fully then worry about an extra 10 seconds before I could start making my sandwich.
Price. Now since I’m not related to any company, not a salesman, etc, etc (remember just a man-on-the-street) I don’t have to be political correct and I can say… If you don’t like the price, don’t buy one. BUT do not bit*h here and say “wah-wah it costs too much, I could build it cheaper, how come they charge so much”, etc. I’m sure Host has figured out what it costs them, factoring in materials, labor, development, advertising and something every business needs, a profit margin. Randall indicated that the Outback 1 and 2 would be about $145,000 to $185,000 depending on model and options. And that of course includes the new Fuso FG that are about $43-45,000 from Mitsubishi. Host will work with the buyer as far as changes such as equipment, but some things like layout have to stay the same. Also Host will install an Outback camper on a Fuso you provide. But they must do the installation to make sure it is done correctly (so no shipping a camper to you, for you to install yourself).
Feel free to ask questions in the thread and I’m sure Randall can give you more accurate answers then my poor memory has provided.
You can contact Randall Pozzi at Host Campers at rpozzi@hostcampers.com or 541-330-2328 ext#6
A review of the new Fuso FG truck will follow.
EarthCruiser
G`day Mog
I think you might mean EarthCruiser, Denver is just a little south of us :)
We will have an off road play day with the OutBack as soon as we get chance.
The suspension Seats and Bull Bar will go on after the holidays.
mog
Kodiak Buckaroo
D'oh, yes you are correct.
I look forward to checking out the EarthCruiser, hopefully someday very soon.
mog
Kodiak Buckaroo
'New' Fuso with 4P10(T5) engine and Duonic automatic transmission
So since Randall was nice enough to let me drive EarthCruiser’s Outback equipped new Fuso FG, I figure a little review for it also. Mine was a short drive, perhaps 15 minutes in Bend Oregon’s not too bad rush hour traffic.
Prior to driving the ‘new’ Fuso, I have to admit I when into it very biased again the Duonic automatic equipped Fuso with all of it's electronics. Yup, if it is not old school, manual transmission and manual 4x4, it was a lesser vehicle in my mind.
Well the on-road performance of the new Fuso is very impressive and proves 'numbers in the book' don't mean much. While on paper it has almost the same horsepower and torque as my 2002 FG, it would run circles around my FG. It drives like a new truck (meaning our 'new' trucks here drive more like cars, then trucks of yesteryear). Performance in town was great, very smooth, fast with great acceleration. The transmission lets the engine rev well and seems to have more of a performance shifting point as opposed to a ‘truck’ feel. Hands down driving in traffic like I was, this is the way to go over my ‘old school’ Fuso. The shift pattern is like new cars. P-R-N then a left side shift to Automatic Drive. From that left point you can up or down shift manually if you like (no need to in town).
I was not able to do a max speed run due to traffic and 'adult supervision' in the cab, but 60+ mph was effortless, and I would guess it would easily exceed 70-80 mph, even with the Outback camper attached. I tried out using the lowest manual gear (transmission only, single speed transfer case) in the dealership parking lot and it seems to be higher then 1st gear (high range transfer case) in my Fuso. But with the automatic transmission, I’m sure this is not an equal comparison.
The feel for off-road performance and highway hill climbing performance can not be judged by my short test drive in town.
I would say that with the new Fuso’s performance, and the lightweight and narrow (84”) Outback camper on back, this would even be a ‘do-able’ truck in town as a daily driver.
chrisdoug1994
Hi been lurking on expo for a while now. Really like the host campers and think the fuso is probably the best truck allround. Just wondering is the outback 2 a brand new camper because at the minute the camper on hosts website is only a double slide out. Also wondering what sort of specs it has and would it be able to have a washing machine fitted. It's a long story but a washing machine is apparently an essential so really looking for a camper that can support one. :)
SkiFreak
Crazy Person
You can put a washing machine in just about any camper, but in order to use them you really need to be somewhere you have access to shore power and access to a ready supply of water.
These things can use around 40 litres of water so you would need pretty large tanks and a generator if you wanted to use it in a self sustainability scenario.
Obviously, they are not that small either, so you would be sacrificing valuable storage space too.
I have seen washing machines in campers before, but personally I cannot see the benefits, given the requirements.
haven
Thanks, Mog!
The triple slide camper must be new. I can only find information on the original hard side, double slide model, which has the rear entry door.
http://www.hostcampers.com/subs/Expedition/motorcoach_300_triple_copy.html
http://www.examiner.com/article/earthcruiser-announces-us-launch-of-outback-and-adventurer-campers-1
http://ww1.prweb.com/prfiles/2013/09/17/11132996/Hershey elevated wheel.JPG
I hope Host and EarthCruiser will provide more information soon!
The criticisms on slide outs for overland use are:
They add to the weight of the vehicle;
The slides don't work unless parked on almost level ground; and
The seals require maintenance to remain water and dust proof.
I'd welcome comments from EarthCruiser or Host on these points. Certainly the makers of large campers for HD 4x4 pickups, such as Host, Lance, Arctic Fox and others, have used smaller slide outs for years.
mog
Kodiak Buckaroo
Yes the triple slide-out Outback 2 (I don't know if that is the official name) is brand new, it is not on the website yet.
I did make sure to ask if it was OK to 'let the cat out of the bag' and Randall said "sure".
Scan (click to enlarge, second click for full size):
OT- I've tried out the Wonder Wash and it works quite well for a small hand powered washer.
Ford Prefect
This is brilliant! I love it!
So, yeah, Do you have any exterior shots of it? The really nifty thing, for me, is that it could likely be easily fitted to a 4 door fuso 6 seater. This could make out to be a really nice camper just for the average family.
The tripple slide, wow, that side slide is massive! It sure looks like it provides an amazing amount of space in there though, so they certainly seem to be doing something correct! I would certainly consider this if I were at that price point. SO they need to figure out how to sell them to the typical average American family, so they can sell thousands, and make millions selling them, and eventually provide a chance for a guy like me to find a nice used one! :)
mog
Kodiak Buckaroo
According to Randall, the 'official' word from Mitsubishi USA is that the 4 door Fuso with be available in the USA as a 4x4 in the next year or 2.
Czechsix
Watching you from a ridge. In Alaska. I'm cold.
Hmmm...guess we'll have to bide our time a bit....hmmmmmm.
I need to give Host a call and see what shows they're going to be going to, if any. Hopefully maybe the Pomona show in October?
DFWSFO
