Expedition Bed Cage - Tent, Awnings and Lights
Oman4x4
Laurie Bridger
A little teaser of something I'm working on - to put the Roof Top Tent, two different types of Awnings, and a Rigid SR50 Amber and Rigid 50" E-Series White light on my Raptor.
The basket that holds all those parts would be removeable for when it's not needed.
Early stages of the design - but interested to hear what you might do differently or add to it.
Oman4x4
Laurie Bridger
Looks good I would make it not mount to the bed. Frame mounted like an exocage
Planning to sandwich the bed sides and then brace to the bed floor. :) Just haven't got that part ironed out yet :)
Exo-cage is an interesting idea though - just don't want to make the truck wider than it already is... already just squeezes through things as it is :)
98dango
If your plan is to mount this on your raptor I would agree. If you brace the bed sides it should hold that's just a lot of pressure on them .
Oman4x4
Laurie Bridger
It looks like your RTT is a Autohome brand. The round tube frame will work. but you will need a larger mount to go over the tubes. This is easy to make, just so you know.
I saw what looked like a center cross bar under the tent. That is a good idea for off-road use. The very front and rear cross bars will not be needed for the tent as the mounting track stop about a foot away from the front and rear of the tent. They could rub on the bottom of the tent against the fiberglass. I would suggest that all of the bars on the top side have some foam weather strip on them to prevent this from rubbing. The round bars do not have as much surface area to spread the weight onto.
Good points. Will check the AutoHome mounting brackets and use a suitable rectangle bar for the cross braces.
TiFJ
Visually I think that looks great. I am wanting to do something similar to my Raptor but was thinking that most of the weight of the rack could be supported by the bed bolts. I had a great pic of something someone had done with a Tacoma (probably on this site) but I can't seem to find it now.
iStan814
