Best battery for JK with fridge
I'm planning on installing a Diehard Platinum Marine 34M battery in my cargo area. I installed a mount for it today. When I finish the charger and wire installation, I'll mount the fridge against the rack on the left side probably using ARB's strap system and secure it at least on the left side to the d-rings on the floor. I'm hoping to get at least 2.5 to 3 days of running the fridge in the middle of the summer without input from the charger. The battery is 100Ah and by taking it down to at most 30% SOC, I should see these results. The charger will output 25 amps when driving. With the wiring I plan on installing for my future solar setup, I can use up to 20 amps worth of solar panels, though I don't plan on installing more than 10 amps worth of solar panels (about 200 watts).
Where did you get that mount? its beautiful!
gp01
