so yeah, I'm right back where I was... does anyone have any thoughts on the 1500/2500/3500 and ford vs chevy vs whatever?   yes i would love a sprinter but they are pricey. maybe i'll look at some numbers with the gas difference, and the high top is sweet.
Since nobody has really addressed this basic question, here is the basic answer.:coffeedrink:
The numbers 1500/2500/3500 are a basic rating for the "heavily duty-ness" of the chassis and drivetrain. At one point in time they actually meant something but nowadays you need to look a little deeper at the whole package. Some modern 1500(lighter duty also referred to as "half ton") can carry and tow more than old school "One Tons"(3500). (Which leaves the 2500 as the 3/4 ton and super lightweights without ratings on them like the Astro as 1/4 tons).
Typically 2500/3500 will haul more, have bigger axles, can have extended lengths, bigger engines ect. They also tend to ride rougher and get worse fuel economy(not always, but "in general")
Realistically, most of what you describe doing could be done with a 1500. (Most conversion vans are 1500) or maybe a 2500 for putting 6 people a dog and kayaks on top. More than that and it's probably overkill for you. (And often times the difference between a 2500 and 3500 is only the springs or axle gears)
Now, I'm sure someone will nitpick that massive generalization of the weight ratings, but it's really all you need to know about them. A 1500 conversion van will ride nice, get decent fuel economy(for a van), have most of the upgrades you need already built in, and be cheap!
As far as Chevy(GMC is the same as Chevy) vs Ford vs Dodge. Unless the Dodge is a Sprinter (which is really a Mercedes not a Dodge:coffeedrink
 then it doesn't really matter for you. They are all basically the same as far as costs to own, power, reliability, etc.  Just buy the best one you can afford.
Good luck!
Fwiw, I've lived off a motorcycle for 6 months. The time to go is NOW!!
