FS: Disco 2 Safari fuel tank
mnfeo2
Im selling a 33 gallon Safari fuel tank made from mild steel. I installed the tank once but decided to keep the OEM tank. There is one minior ding on the corner where the powder coating has chipped off and there is also a thin layer of rust inside where it sat in customs for so long. I purchased the tank from Lucky8 for $1050.
Im asking $500 and dont want to ship it if I dont have to. I would be willing to meet somewhere if it helps.
Im located in Joshua Tree, CA.
Chazz Layne
Administrator
I've long thought about getting one of these, but haven't been able to find photos of one installed. How much ground clearance is lost, and is there any cutting required on the body to get it installed or is it just bolt on?
mnfeo2
Just bolts right in using the factory pump/sending unit and gasket. The tank sits higher than the stock tank so you only loose 4 - 5 inches if I remember correctly.
Goldenbora
