M1078 truck
brian90744
American Trekker
was looking thru gov surplus and found a good start for someone, =MFG. date of 1993 Delivery date of 1995 Stewart and Stevenson M1078 Cargo LMTV, Manufacturer's serial number: AT0172BHB, no hour meter, Odometer reads 000388, Cab over hydraulic tilt cab, hydraulic lift, 3116 Caterpillar motor, 168 hp, 7 speed Allison Transmission. Max payload 2.5 tons. Vehicle equipped with a hard top and has a spare tire. Unit runs. Transmission works. Interior fuse and relay cover missing Current bid is $8K @ Government Liquidation site.
well I guess this truck was SOLD for $14775. Somebody will have a great truck..
Scoutman
Do it, put a 12' Alaskan with the overhang boxed in behind that spare tire and post picts. :coffeedrink:
bob91yj
Resident **************
I was an Allison Transmission Field Service Tech for 10 years or so, that transmission is damn near bullet proof.
Guri
Somebody know what is the cruise speed of that truck? It looks a rock solid platform.
mog
Kodiak Buckaroo
was looking thru gov surplus and found a good start =MFG. date of 1993 Delivery date of 1995 Stewart and Stevenson M1078 Cargo LMTV.
A good thread on the Expo Portal HERE
And a build on a commercial 6x6 HERE
From LoRoad's thread:
The truck is on it’s way to have the gearing changed out from the 7.8:1 ratio to the 6.14:1 ratio and having the ECU for the transmission reprogrammed (aka ‘flashed’) so that everything changes gears at and when it should as well as having the speedometer post the correct speed.
Top speed under the lower gear ratio was 58mph and at apx. 2400 rmp. Under this new ratio the top speed will be governed at 70mph with an apx. 2400 rmp and at 65mph rpm’s would be apx. 2200.
Mundo4x4Casa
West slope, N. Ser. Nev.
I don't know, but I've heard that it is impossible to get the CAT engine smogged in CA as it is a military, unsmogregulated engine. Is this true?
I do like the looks of the platform though.
jefe
D
Deleted member 9101
Guest
Go for it, those things are awesome trucks. I have driven them for about 10 years off and on, never has a problem or a break down. They ride good and can keep up in traffic when fully loaded. Best part is they have a crane to help you get to the spare tire.
Plus, they sound really good...lol.
V45W_Proto2.5
