Confession | Forward Control
TJDIV
We're fast-tracking this project for the Dome Show in Marquette MI at the end of March. We'll be updating as the build ramps up.
Short list:
Donor solid axle Grand Cherokee - rebuilding the 4.0L.
Military bed (M105) that's getting chopped.
And fabrication. Lots of it.
A few pre tear-down images. Stay tuned:
NMC_EXP
Debating wheels ( MT ) and tires ( Duratrac ) today. The tires on it now are brand new... may just paint the wheels and be happy with it?
-Tom
If you do some research I think you will find that white painted wheels were common on trucks back in the day. Can't say if this applied specifically to the FC.
tjtoytech
Drivetrain
Pulled the 4.0L out of the donor and began prep for the transplant.
Ordered up a list of new parts to freshen up the powerplant.
-Machined Resurfaced Head - Valve Guides, Pressure Tested
-Head Bolts and Fresh Gaskets
-High Flow Water Pump
-Oil Pump
-Complete Ignition (Coil, Dist Cap/Rotor, Plugs, Wires)
-Timing Chain/Gear Set
-Crank Sensor
-Oil Pressure Sensor
-JBA Header to Replace the Cracked Stock Manifold
W038K7RkzrGMHm_UaDkY1wxfmoVvMHr8aTFIm9j2kCw=w386-h513-no
Fresh Paint on the Block, reassembly, and she'll be ready for new fluids in no time
TJDIV
Now we need to find an appropriate project for that 289 Ford :)
Good find on the 4.0. It's going to be a sweet driving rig.
upcruiser
Perpetual Transient
Strike that last question, just saw the comment about the new bed. Sounds awesome. You guys going to drive it out and visit this spring??
DanoWall
