Recomend an Android based tablet
SGTCap
I'm in the market for a tablet and the options have become overwhelming. I'm hoping you guys can help point me in the right direction. I'm looking for Android based in the 8" class with a removable micro SD card. This will be for personal/recreational use and as a GPS in my truck. Any help you can offer on both tablets and mounting solutions (05 Tacoma) would be appreciated.
ExploringNH
I'm in the same position as you and trying to make a decision.
For me, I think I have it narrowed down to the tablets that are proven to work on T-mobile so that I can take advantage of their free data plan. It's a small amount of data but enough to run GPS. Compatible tablets are listed here: http://support.t-mobile.com/docs/DOC-9700 . There are lots of options in the 7-8" range. I am leaning towards a 10.1" tablet right now for more of a multi-purpose machine. It will be a little big for nav but I have a big truck so it won't be as in the way as a Tacoma.
java
I have a Nexus 10, its very nice. No SD card though. But you can get an external HDD thru USB.
java
Nexus 10 doesn't have 3/4g, right? How do you handle mobile GPS?
Correct, I use BCN and just download the maps for the area i'm headed to. It has internal GPS. In a pinch my phone can run as a mobile hot spot which can provide the internet connection to the tablet.
Mapcinq
Ive got a Nexus 7, it works great. Nexus 10 would be good as well.. they are pretty similar. I use the GPS on it the same way as the guy above mentioned, but I also have a GPSMap 62. I have it mounted on a Tech Deck, along with my gps.
SGTCap
you want mobile connectivity or wifi only?
WiFi only. I can use my phone as a hotspot if needed but I pay Verizon to much as it is, I don't want to add another data plan.
Sent from my DROID RAZR using Tapatalk
XTorrey
It's not Android based, but I like my Kindle Fire if you'd consider that as an option
Sent from the wastelands of Tatooine
Herbie
Rendezvous Conspirator
Just a crucial point: I'm normally a huge fan of the Nexus products (I'm on my 3rd Nexus phone), but I don't think they're the right choice for this application.
Whenever anyone mentions the lack of external storage, the next sentence is usually that you can use USB OTG to plug in a USB stick. The problem nobody mentions is that enabling OTG *disables* charging. So, even if you're willing to build a custom cable, you can't have a semi-permanent setup where you can have expended storage without running on battery.
IOW, you'll be switching back and forth between charging cable and expanded storage...
Sent from my Nexus 5 using Tapatalk
java
This is true, but double usb to micro USB cables are $10.
SGTCap
Actually I did look at the Kindle Fire, although I thought they were android based. What do you use to downloads apps ad what apps are you running for GPS and mapping.
My big draw to the Andriod OS is the Google Play store.
Thanks for the heads up on the Nexus. I'll keep it in mind although I really would like to keep the expandable memory contained in the unit itself.
reece146
Automotive Artist
Kindle runs an Amazon forked version of Android. The Google Play store is not available on Kindle fire... Maybe if rooted.
For device longevity stick with mainstream, well supported devices. My short list is Asus, Nexus, Samsung (in any order).
java
Look at the samsung Tabs then. They can do up to 32GB micro SD
Herbie
Reread my post: "even if you're willing to build a custom cable, you can't have a semi-permanent setup where you can have expended storage without running on battery."
The issue is not the cabling. The issue is that switching the USB port to HOST mode changes the power pins from inputs to outputs (per USB standard, HOST always supplies power to the bus). The Nexus hardware is physically not capable of accepting a charge while it's set to HOST mode.
Henrybrowne
