Box Rocket
It wasn't long after we crossed the washout that the sun was down and it got dark quick. Almost like the weather had planned it with the darkness, once the sun went down the rains picked up again. It was never a total downpour but enough to keep the already saturated ground wet and sticky. Low areas that were soft became a challenge.
The trail had started to wind through some switchbacks with exposures and the wet sloppy trail made it sketchy as it was difficult to keep the trucks going in a straight line.
Over the radio we got the call for shovels and Maxxtrax. Kurt had come to another washout and the trail on either side was sloppy clay. We needed to somehow fill the section that had washed out. It became apparent that the line we needed to take was the high lefthand line as the righthand side got deeper and farther to cross and was also off-camber. I apologize for not a lot of photos through this section since it was dark and raining.
Everyone that was out helping to move rocks, place maxxtrax etc was covered in mud as it was really getting sloppy. We found some logs that we placed in the ditch and Kurt tried to inch his way across. But as his tires got close to the edge the bank started to give way risking a sideways flop into the ditch.
We found a stump up the hill and hooked up the winch, partly as a safety line and also to help drag the heavy cruiser through the slippery muck.
Soon the front tires were across but the trail was still breaking down. Rather than make it a worse situation for the rest of the trucks we did a little more road building before Kurt made it all the way across.
It worked and Kurt successfully winched across. The trail made a right turn just after the ditch so winching from the trail would pull trucks into the deep part of the ditch rather than across. Kurt positioned his truck about 50' up the trail pointing back at the ditch and we ran a snatch block over the the stump that Kurt had winched from. This game us a straight line pull across the ditch for the other trucks. We had used all of our recovery equipment in the spot. Shovels, straps, winch, maxxtrax, lockers and a decent amount of roadbuilding. While the snatch block was set up we found a couple more large logs to place in the ditch. This helped stabilize the crossing and give a better route. Cody and Dan and Ja and Troy both made it across with some extra help from the winch. As each truck crossed it churned the mud on either side of the ditch making it extra soupy. Paul May was the most challenged here with his BFG ATs. He couldn't quite enough traction and he was also winched across.
Then it was my turn. As I looked at it I figured I could make it across without the winch. I wasn't worried about taking a winchline but we were hours behind schedule again. It was almost 11pm and raining. I just wanted to get us through as quickly as possible. I was able to keep a decent (although somewhat sideways) line through the muddy approach and then hit the gas. The front went across and as the rear came across I could feel it slide sideways and the passenger rear tire dropped into the deeper part of the ditch. Don't ask me how but I got lucky and with a good amount of throttle I clawed my way across unassisted. Dave Connors was the only truck left and he was able to do the same.
Then the search started for the 6 Maxtrax that were buried somewhere in the muck.
