WTB: SoCal - 2 JKUR wheels and tires
Burnsy949
I am looking for 2 JKUR tires and wheels for my Adventure Trailer. Trailer has 315/70/17 BFG ATs, which I would consider trading. Wheels on the trailer are not JK pattern (they are 5 x 5.5). I am changing out the hubs on the trailer to match the JK bolt pattern.
Pic of the trailer below.
Fhunter1
You might want to clarify which one's you are looking for. The new 2013+ wheel or the older spoke design. The older spoke ones came in 2 sizes, either a 16 or 17 inch wheel.
Burnsy949
Thank you. I am looking for the newer 17" wheel. I'm ok with the 2007-2012 Moab style, but prefer the newer 2013/2014 design.
Fhunter1
I see 2013+ ones on Ebay regularly for around $135-150 each. The old 5 spoke ones (17") around $75. Check Craigslist and you might find a good deal
Another option is the steel Mopar Winter wheel or Grand Cherokee steel spare. It's a nice look, but adds 14lbs over the factory wheels. I have the part numbers if you want them.
I am going through the same process with my Conquerer Compact right now. I found some of the all black MOAB wheels that match my Jeep on ebay last week, but had to buy 4 when I only really needed 2. Keep in mind you will likely need wheel spacers because the Jeep wheel hub is very small compared to the cast brake drum.
Burnsy949
Many thanks Frank! If you were closer I'd buy the other two black Moab wheels from you for my trailer. Not sure what shipping would be from Detroit, but I'd consider it. Did stumble on to the single wheels on Ebay yesterday. May be my best option for a match.
Good info on the spacers. The current wheels on the trailer are 17" - they don't require spacers but may have a bigger hub clearance than the JK wheels.
One day I am planning to go with 35s which will require different offset, so thinking about just getting AEV wheels for the trailer now(2) and upgrading the JK later.
