Antenna/Roof rack
unseenone
Never seen one of those installed on anything. Keep in mind it's NVIS so it would not do you a lot of good for DX. You can do quite well with an ATAS120a and only need one antenna. What vehicle are you planning on mounting it on?
robgendreau
I saw a reference to one of those somewhere else, and found this at 4x4ham:
http://www.4x4ham.com/showthread.php?1735-HF-Mobile-Magnetic-Loop-Antenna-(Part-1)
I kinda stopped reading when I saw the price ($5k) and the fellow's comment about RF exposure inside. I get the impression these are for professional use and not mere mortals. The link above does mention some DIY NVIS antennas. I was thinking of getting the same radio, but I am thinking more of a Buddipole or something. But I still use mostly just 2M in the vehicle. But I'd think even if you got a roof rack antenna you'd want something that could be used off the vehicle since in a wreck the rack might be shot. Ditto for the ATA. But if you can afford the 9400 you can afford backups galore.
gary in ohio
Have you priced that antenna? $5K and its only covers 20-10m... No 40 or 80m. Takes the entire roof and is not designed to use while in motion. Its mainly a point to point antenna. Its going to be a PIA to interface to most ham gear as its designed to be used with Barrett commercial HF radios. A high end screwdriver antenna would be a good option but is not roof mounted.
Frdmskr
Go read K0BG's web page. Then install a Breedlove mount. Then ham sticks or a 102" whip on the trail or a screwdriver elsewhere.
rambrush
How bout I 3rd Breedlove Mounts? I
have one on the side of the truck with his aluminum plates and that is rock steady. Had the screwdriver mounted on it.
AFBronco235
Crew Chief
I went with a twin fire stick combo from RS for my own setup and mounted them on gutter mount clamps. No problems so far. I pick up signals over 2 miles away in city and more in open terrain. The clamps were $4 apiece on Ebay. I did have to modify (read bend) them to get them to work with my antenna, but I can't complain with the results.
attachment.php
This was designed more for a big rig, but I like how it turned out.
The only downside is my clearance is now at 9' 2" which is 2 inches taller than the local drive through!
attachment.php
Frdmskr
Gutter mounts will rip off when fighting trees and other solid, immovable objects. Definitely for safety and security drill a hole. No reason not to.
From a pure physics standpoint that antennas stick is half an antenna. Where is the other half? It's the vehicle. Need to have a strong electrical connection which that gutter mount does not have. Might see a huge improvement at that point.
AFBronco235
Crew Chief
I agree with you about getting them ripped off by a tree. I plan on getting a better mount soon with springs.
As for grounding, it looks to me as if the setup wasdesigned to insulate the antenna from tthe rest. I do agree that the mount needs grounded, but not because my rig acts as part of the antenna.
Frdmskr
Ok here is a set-up to consider looking at your truck. Looks like that Bronco has a wide spot on the front quarter panels. So put in an NMO mount on the Driver's side and then use a Larsen NMO27B. Run the coax through a grommet on the driver's side and connect to the CB. It'll be nearly invisible inside the rig.
Why this set-up?
It's a base loaded antenna. The whip can hit things and, if you install the mount correctly, that thing will never break. No need for a spring. That NMO mount is water proof and nearly indestructible if installed right. Given how low the coil is on the rig it will not get abused unless you are in a heavy brush environment or *God forbid* roll it.
That will solve the grounding issue and everything nicely. Also give you a workable ground plane. Plus if you are a ham (or become one) probably could use the same antenna for your 10m rig.
AFBronco235
Crew Chief
Why this set-up?
I'm not a big fan of drilling into body work. Instead I've decided to go with a set of brackets and springs that mount the antenna at the sides of the hood, between the hood and quarter panels. If that doesn't work out, I've got a few other ideas to try.
I doubt I'll be going with anything other than CB for a while so what I've got will work fine for now.
oskarf150
