which jeep??
toylandcruiser
According to that all-par link, the waggys weighed 3758 when they were introduced in 63, but by 1975, R&T tested one at 4760. And the all-par chart listed the 1990 at 4500.
Don't get me wrong, the old full sizes were awesome, but they were not lightweights...
So they added over a 1000 pounds of stuff huh. How do you explain my 81 weighing 3700 pounds?
I could be wrong but I remember being how surprised I was when they gave me the piece of paper stating it was only 3700 pounds. Granted it was a basic 6 cyl and 4 speed. Unfortunately I sold the cherokee. Later on I purchased a scout. Once again I took that to the scale and weighed it. With the top off it weighed 3900ish pounds. I do miss the cherokee. I taught myself how to drive a stick in it. Driving all over the hills and mountains around my house.
"I ask, sir, what is the militia? It is the whole people, except for a few public officials."
— George Mason, in Debates in Virginia Convention on Ratification of the Constitution, Elliot, Vol. 3, June 16, 1788
Fleg
I know the SJ's are not light weights but a reoccurring point is that the ZJ is sooo much lighter. The truth is they weigh about the same. My 1981 cherokee is a fat girl and weighs right at 4,000 lbs verified on a scale. Curb weight of a ZJ is reported to be 3926lbs.
WrenchMonkey
Mechanical Animal
Hey, sorry, I didn't mean to call anybody a liar. I've never even had the chance to drive one, much less weigh it.
I was just pointing out that, according to the link provided, the later models were supposed to be much heavier.
And according to this link, the early ZJ's curbed at just 3,575 lbs.
God knows you can't believe everything you read on the innerwebz, but if we do believe those two sources, then we're talking about a 1200 lb difference. That, my friends, is HUGE.
Robert
Fleg
Robert
If you would have kept on reading in that link you have have found this;
1996-98 ZJ Dimension changes - (If not shown, it did not change)
Exterior:
Length: 177.2 in. Width: 69.3 in.
Height: 64.9 in. Wheel Base: 105.9 in.
Ground Clearance: 7.7 in. Curb Weight: 3926 lbs.
Since we are comparing a 1996 ZJ. So the real world difference is a whopping 74lbs. Hardly enough to sway a decision one way or the other.
toylandcruiser
And I apologize. I wasn't trying to start a peeing contest. Just showing my experience with them.
Fleg
I also am not trying to make an issue over this but when I originally read this thread weight was mentioned several times. All I'm saying is weight between those two vehicles are not a big difference.
WrenchMonkey
Mechanical Animal
No, I saw that the later ones were heavier by 500#. That's why I said "early ZJs." But even comparing the later, 4000 is a far cry from 4500-4800 (all-par's numbers.)
Apparently, there is some pretty wide variance on what these individual rigs end up weighing. But generally speaking, going by published (average?) curb weights, a ZJ will be several hundred (even a thousand) pounds lighter.
toylandcruiser
But please don't think weight means strength.
WrenchMonkey
Mechanical Animal
Oh no no, just the opposite: I'm a big fan of lighter is better.
My XJ drives like a whole different vehicle when I take the 200# of doors off. It accelerates better, handles better, climbs better. I can only imagine the difference if I could shave six or even eight hundred pounds off it.
Conversely, adding 600# of armor, tools, and spares turns it into an absolute dog. Been there, done that, learned my lesson...
Buddha.
Finally in expo white.
Back on point, if I was looking for a budget DD it'd be the zj. Off road only I could go either way.
DanoWall
