Anyone have pix of how they mounted solar panels
LandCruiserPhil
geordie4x4
THIN FLEXIBLE SOLAR PANELS
That's very nice. What panel is it, and where did you get it?
The thin panels have come a long way in just the last few years. Thin, light weight, high efficiency mono cells.
The one on my hard shell roof top tent is attached with silicone sealer and small stainless screws. But this was a cheap Chinese made roof top tent so I was not too worried about drilling holes in it. I am just selling it now to get a much more expensive James Baroud to which I will also be fitting 2 x 100W thin panels.
The one on the camper in the photo is the same as this ebay one but I bought it from a local shop in Perth West Australia.
http://www.ebay.com.au/itm/like/221...e&hlpv=2&ops=true&viphx=1&hlpht=true&lpid=107
There are also a lot of new panels coming out with the highest efficiency US made SunPower E20 cells but the panels put together in China.
https://solar4rvs.com.au/solar-panels.html
http://www.kulkyne.com/au/125W-semi-flexible-solar-panel.html?gclid=CJv71cz8rr4CFceUvQodC14Alg
There are also a few that now do these panels with an EVA plastic back not aluminium. These are even lighter and more flexible. They being plastic do not soak up and store so much heat as aluminium, so thend to be more efficient as they are not as hot.
http://www.ebay.co.uk/itm/Semi-Flex...fficiency-Sunpower-Marine-Rated-/131179546342
http://www.sacredsolar.com/index.aspx?menuid=12&type=introduct&lanmuid=26&language=en
Also the same high efficiency E20 cells and from a european manufacturer made for high end yachating etc. these are a lot more expensive but probably better plastic materials and quality. I like the ideas for attachment in the link to Marine use, you can zip them on to an awning, glue them on to a flat surface, use eyelets or stud type Tenax clips. There are aslo options to have no junction box sticking up and connect cables from the back for a completely flat top that you can walk on.
http://www.solarfuture.com.au/caravan-camping/camper-packages/
http://www.solarfuture.com.au/marine/marine-packages/
Solbian brand are meant to be the best but have a look at the pricing here, not cheap. You might be able to find them at a better price in the US.
http://www.solarfuture.com.au/products-pricing/solar-panels/
ripperj
Not mine :) several bungies and 20ft of perf angle.
P's if you paint your generator to match the van it won't get stolen off the roof.
Sent from my Z10 using Tapatalk 2
geordie4x4
Ah I like the simple approach, but I bet that thing whistles in the wind at speed.
geordie4x4
100 Series ITE 55 watt frame panel
80 Series GS 100 watt (.12" thick) flat panel
HI LandCruiserPhil,
I like you Cruiser and the dog (it looks like a blue heeler/black and tan kelpie cross, that I had as a cattle dog in Australia).
Anyway regarding the thin solar panel, what brand is that one.
Is it EVA plastic backing rather than aluminium. Also it has a really slim neat junction box to the cables rather than the normal big square box. I will have a new rooftop tent in a few weeks and am planning on two by 100W panels so need to find neat slim panels to fit side by side.
This is what I am thinking of, the panel looks like what you have and seems to have the slim junction box.
This is also nice but a lot more expensive:
http://www.solarfuture.com.au/wp-content/uploads/2012/12/SP100-L.pdf
LandCruiserPhil
HI LandCruiserPhil,
Thanks and Yes a Blue Heeler and as you know great dogs.
Your first link looks almost exactly as mine from Grape Solar out of the US state Oregon. The only difference aside from your being less expensive is the grommets that I asked to delete. It has seen its fair share of abuse from tree branches and held up well. I would recommend it to a friend.:sombrero:
Crom
Expo this, expo that, exp
Yes. I have driven every day for an entire year like that, over 10K miles. I'm using the 15" variety tarp straps. and their petty tight. I recently inspected them and decided it was time to replace them due to sun rot. If they weren't stretched so tight they'd last longer.
They see sun practically every day of the year in San Diego.
I swapped the old tarp straps for 550-cord. I'm going to use that for a while instead.
Thespoon
LandCruiserPhil
Absolutely off topic……..nice to see an Australian Cattle Dog/Blue Heeler guarding your Land Cruiser….. You could not have chosen better !!!!
Adrian
(Australia)
LandCruiserPhil
LandCruiserPhil
Adrian
(Australia)
Not only is the beaches in Mexico one my and the dogs favorite places it was also the need for ice cold beer that got us started in solar.
Colin Hughes
I kept over thinking this as I wanted to mount the panel as flat as possible using the factory rails. I kept trying to find something custom. Here's what I came up with. It's very solid and I can still install my Thule racks for my canoe, etc with the panel in place. Haven't noticed any wind noise either. I used an oversized washer on the inside and ground down two sides of it so it fits tightly in the track. Sheet metal self-tappers hold the L-bracket to the panel.
Dan Grec
Crom
View attachment 228399 View attachment 228400
Brilliant! Your panel assembly looks like it fits perfect between the mounting rails. Do you have a top down photo?
