Accrete
SORRY for the mis-name of product i used inside our van... it is "Reflectix"
Available at Lowes and other places.
Link at Lowes online.
I did spend some time with no interior in the van so I can relate to the cargo van experience, "I never noticed so much gravel on good asphalt either"...I also have an Express AWD 2010. The one I have is a cargo. There is no insulation around the back Wheel fenders. I dont know if you have the same problem. When I drive during a rainy day, I hear all the water that hitting the inside fender. I dont know if I put Gravel Gard inside the fender if it will reduce the noise. What do you guys think about it??
Congrats on the van. I'm envious. I'm currently in the market for a 1500 AWD and have been following this thread and the other 1500 AWD threads. I keep going back and forth on a cargo vs a passenger. The extra windows would be nice but so would the panels for privacy. The ducting for the heat/ac looks like a big plus. I have a few questions....
Did you install the rubber floor mat over the carpet or did you remove it or maybe leave the padding? And how hard/easy are the interior factory wall panels to remove/replace?
I talked to a couple guys about professional bedliner application on the rockers and they both wanted to get to aggressive with the paint for me (I am thinking Sotchbrite they are thinking 36 grit). They were more worried about it coming off the paint for warranty issues than long term corrosion protection the factory primer and paint provide.
Hmmm, that is good to know. My main reason for putting bedliner on the rockers and arches would be for the added corrosion protection...
:drool:
Thom your van is looking great.
...I knew immediately it was your van he was talking about. So we yacked and drooled about your van for a half hour.
So I think that may make yours the most famous awd chevy ever if two strangers from opposite sides of the country can meet and both know your awesome van.
So that's my boring story.
Not to take this thread too far off track, would you mind sharing a ballpark price of what the rhino liner set you back?
Later
Danny
Great timing on this thread. Have you done any towing? And if so what and how did it do? I really like the gm, just want to be able to hit the beach and light trail access roads, but need to pull a camper or a car trailer
I'll share my towing experience with our chevy 1500 AWD van conversion. As mentioned elsewhere our rig is sitting just under its 7K GVWR...so in our case i don't want to exceed a trailer weight of 5K...getting the total up to the GCWR of 12K. Our set up is currently the van conversion (as bed & bath) towing a 2,300lbs at scales 15ft fiberglass trailer (great room/kitchen/shower). We just came back from an easy ~300 mile camp out (of that ~50 miles under 40 mph). I can say that sitting at ~9.5K total rig we have times on the highway going up a grade when the auto-transmission would be happier with a different ratio. On hills we tend to pedal-to-metal when passing and will easily go from ~55 to ~70. Flats it does fine ~65 all day long towing....Have you done any towing? And if so what and how did it do?..
