1984 Toyota Pickup Truck 4WD Ivan Stewart Baja Paint Job - Fully Restored
baja_banana
SOLD !!!
1984 Toyota 4WD Complete Restoration. This is a new truck! Sold in Phoenix, Arizona new in 1984 and has been in Phoenix all of it's life so NO RUST what so ever. Painted like the Toyota Desert Race Trucks of the 1980's. 100% paint graphics. Featured in the Jan/Feb 2014 issue of 4WD Toyota Owner Magazine. Click Link below for that article. The truck has Air Conditioning, Power Steering and Power Brakes.
SOLD !!!
Vehicle and parts have 7,360 miles since restoration.
Front Diff, Toyota 8” 4Cyl
Solid collar, all new bearings & seal
ARB Air Locker, Factory 4.10 gears
Rear Diff, Toyota 8” V6 from 1996 4Runner
Solid Collar, all new bearings and seal
Rebuilt 22R Engine, short deck (7,360 Miles)
Marlin Crawler Rebuilt G54 Transmission (Marlin himself signed it) (7,360 Miles)
Sonoran Steel Rebuilt Transfer Case, Trail Gear 4.7 Low Range Gear set, Case clearance by Marlin Crawler, Marlin shift rail springs and top shift cover, Marlin output Eco-seal, Factory Toyota t-case rebuild kit, new speedo gear and O-rings.
Spidertrax 1.5” Wheel Spacers up front to match the width of the 1988 Rear Axle.
Powder Coated Restored Aisin Lock Out Hubs: Red/Black
Front Trail Rock Defense Gear Tube Bumper
Trail Gear LED Front Turn Signals
Resistors to slow down blinking of LED turn indicators
Warn M8000 Winch with remote mounted control box
Amsteel Blue synthetic winch line
Factor 55 winch line thimble
PIAA 520 Off Road Lights
New Front Grill (Aftermarket)
New Headlight Doors R & L (Aftermarket)
New Left Side Corner Light (Aftermarket)
New Right Side Corner Light (Factory Toyota)
New Hood (Factory Toyota)
New Right Fender (Factory Toyota)
New Wiper Arm Covers (Factory Toyota)
New Washer Squirt Nozzles and Gaskets (Factory Toyota)
Used 1988 4Runner Cowl Vents with additional screens
New Rubber Radio Antenna
New Windshield with New Gasket and Custom Gasket Conversion
New Sears/Odyssey Battery 34/78 DT
New Radiator, Performance Radiator
New Radiator Shroud (Factory Toyota)
New Radiator Hoses (Factory Toyota) Extra Set included
New Fuse Box Cover (Factory Toyota)
New Fan Clutch (Factory Toyota)
New Oil Pump (Factory Toyota)
New Front Main Engine Seal (Factory Toyota)
New Water Pump (Factory Toyota)
New LC Engineering Front Engine Cover
Added Power Steering, PS Box, PS Pump & PS Reservoir
New Spark Plug Wires (Factory Toyota)
New Spark Plugs (Factory Toyota)
New Distributor Cap (Factory Toyota)
New Rotor (Factory Toyota)
New Valve Cover Gasket and half-moon seals (Factory Toyota)
Rebuilt & Tuned Carburetor by Jimmy at Scottsdale Automotive
New Air Intake Hose (Factory Toyota)
New Hot Air Hose (Factory Toyota)
New Trail Gear FJ80 Brake Master Cylinder
New Aisin Clutch Master Cylinder and Slave cylinder
New Aisin Clutch Kit, Disc, Pressure Plate and Throw out Bearing
New Rear Main Engine Seal (Factory Toyota)
New Clutch Fork, Pivot Ball, Fork Boot & Throw out bearing clips (Factory Toyota)
Re-Surfaced Flywheel
Blue Seat 12 port auxiliary fuse panel
Summit Racing Rear Brake Proportioning Valve
Electronic Line Locks, Front and Rear, This is the super strong parking brake.
New Alternator (Factory Toyota)
New Regulator (Napa)
New Sylvania Silver Star Headlights.
New Heater Hoses, Engine Bay (Factory Toyota)
New Heater Core (Factory Toyota)
New Exhaust Header/Down Tube (Aftermarket)
New Exhaust down tube bracket (Factory Toyota)
Custom Exhaust, High Clearance
New Flowmaster 50 Muffler
New Catalytic Converter
Custom FJ62 Land Cruiser Slip Steering Shaft, TIG welded and balanced
Custom Winch Control Box, Fuse and Relay Bracket
New Horn from 1990 Toyota Pickup (Factory Toyota)
New Fuel Pump (Factory Toyota)
New Reed Valve, improved from 1987 (Factory Toyota)
New High Pressure AC Line (Factory Toyota)
Fresh charge of R12 Freon
New AC Evaporator (Factory Toyota)
New Manifold Temp Sensor (Factory Toyota)
New Drive Belts and Fan
Original Front Skid/Cover Powder Coated
Front and Rear Diff Breathers
New Radiator Cap (Stant)
New Battery Cables (Factory Toyota)
New Small ARB Air Compressor
Front and Rear ARB Air Lockers
New Hood Seal, Side Rubbers and Front Bumpers
New Battery Bracket (Factory Toyota)
New Starter (Factory Toyota)
New Valve Cover Sticker “22R” (Factory Toyota)
New Air Cleaner Sticker (Factory Toyota)
Factory Steel Wagon Wheels, Sand Blasted and Powder Coated
New Steering Drag Link (Factory Toyota)
New FJ60/62 Tie Rod Link (Stronger) (Factory Toyota)
New FJ60/62 Tie Rod Clamps (Factory Toyota)
New Steering Dampener (Factory Toyota)
New Sway Bar End Links and Bushings (Factory Toyota)
New Old Man Emu Front Leaf Springs CS008FA/B (Two)
New Old Man Emu U-Bolts OMEU52 (Two)
New Front Leaf Spring Bushings, Daystar
Rebuilt V6 IFS Calipers (Napa)
New FJ62 Rotors (Auto Zone)
New Brass Axle Spindle Bushings (Trail Gear)
Marlin Crawler Front Axle Rebuild Kit (All Japanese Parts)
Marlin Crawler Front Wheel Bearings (All Japanese Parts)
New Braided Stainless Front Brake Lines, Extended
New Bilstein 5150 Shocks, All 4 Corners
Sky Mfg. Weld on Diff Covers, Front and Rear Axles
Custom Made Front Anti Wrap Bar, Spidertrax Bungs, Heim Joints and Seals it covers
Custom Made Aluminum Diamond Plate Door Panels – Powder Coated Black
New Door Seals L & R (Factory Toyota)
New Window Seals, Base of the window, inside and out (Factory Toyota)
New Window Track Seals (Factory Toyota)
New Interior Door Releases (Factory Toyota)
New Interior Door Release Background (Aftermarket)
New Interior Door Handles (Factory Toyota)
New Interior Door Window Cranks (Factory Toyota)
New Interior Door Lock Levers (Factory Toyota)
New Interior Door Lock Lever Surrounds (eBay from Singapore)
Original Port Installed Side Mirrors
12V Guy Cab Winch Control Panel
Used Gauge Cluster with 110 mph speedo
New Speedo Cable (Factory Toyota)
New AC/Heater Face Plate (Factory Toyota)
Used Quartz Clock, 1987 4Runner
Used Radio Surround, Uncut
New Radio Mounting Brackets (Factory Toyota)
New Panasonic AM/FM/CD/MP3 High Power Stereo, iPod and RCA inputs
New Pocket Under Radio (Factory Toyota)
New Rear View Mirror, tilting (Factory Toyota)
Used Sun Visors from 1985 Pickup
New 3rd Gen 4Runner 5-Speed Shift Knob (Factory Toyota)
New 3rd Gen 4Runner T-Case Shift Knob (Factory Toyota)
New Pioneer 2 Way 6.5” Door Mounted speakers
New Hopkins Center Console
Sports Car Bucket Seats, Tan, from unknown sports car
New Hook and Loop Carpet
New Husky Floor Mats
Powder Coated Shift Boot Surround
New Reproduction Seat Belts (The Parts Bin)
New Cigarette Lighter and Outlet (Factory Toyota)
New Flasher Module (Factory Toyota)
3 ARB Switches, Rear Locker, Front Locker and Air Compressor
New Exterior Door Handles L & R (Factory Toyota)
New Door Latch Strike Plate
New Cab Vent Covers L & R (Factory Toyota)
Stubbs Welding HD-SKO Rock Sliders
Real 1980’s Smitty Built 3” Tube Double Roll Bar. For 84-88 Toyota Pickup
Roll Bar was: Stripped, Sandblasted and Powder Coated
4 New KC Highlights with covers
Inyati Spray-In Bed Liner
New Tinted Sliding Rear Window (CR Lawrence)
New Rear Window Gasket (Factory Toyota)
Side windows tinted L & R, 50 state legal
New Tail Gate Handle (Factory Toyota)
New Tail Gate Stops and rubber bumpers and anti-rattle clips (Factory Toyota)
Trail Gear Rock Defense Rear Tube Bumper
Draw Bar and 2” Ball for TG Rear Bumper
New Tail Light lenses and rubber seals (Factory Toyota)
Sky Mfg. Rear Disc Brackets, Rotors and GM Monte Carlo Calipers
New Rear Axle Bearings (Factory Toyota)
New Rear Axle Outer Seals (Factory Toyota)
New Rear Axle Inner Seal Collars (Factory Toyota)
New Rear Axle Marlin Crawler Eco Seals
Rear Axle Tube from 1988 Toyota Pickup, Sand blasted and re-painted
BudBuilt Singe T-Case Cross member - The Original and the Best!
Re-Arched and rebuild stock rear leafs with bolt style keepers – Dunbar Spring
Trail Gear U-Bolt Flip Kit
Daystar Rear Leaf Bushings
Custom lower shock mounts
Stainless Steel Bottle Opener
New Rear Axle Brake Hard Lines (Factory Toyota)
Rear Drive shaft balanced and new U-Joints (Phoenix Rack & Axle)
Refurbished Front Drive Shaft (Phoenix Rack & Axle)
Extended Diff Breathers, Front and Rear
Custom Rancho FJ40 Poly Bump Stops, Rear
3 BFG KM1 tires (1/2 Tread) and 2 BFG KM2 tires (New), 235/75/15
New Fuel Tank Sender Unit (Factory Toyota)
New Energy Suspension Body Mounts
¾” Body Lift to place the body the same height off the frame as the 1986-1988 Trucks
Braided Stainless Rear Brake Line
New Silicone Factory Oil Pan (Factory Toyota)
New Oil Pan Bolts (Factory Toyota)
Trail Gear Magnum Knuckle Studs ARP (8)
2 – ¾” D Rings
Led Interior Light
Below is the over heat indicator the re-builder put on the engine, this motor was indeed rebuilt.
Marlin of Marlin Crawler signed the transmission after he personally re-built it.
Link to magazine article below!
baja_banana
Rear ARB Install into 1996 4Runner V6 Third. New Bearings and fullre-build. We moved the ARB from a 4CYL diff to the V6 diff.
landman
Considering I bought Steve's last truck (Red Truck), I have first hand and unique experience with his builds. I can personally vouch that his attention to detail and quality in build is TOP notch. He never cuts corners and everything is done with no expense spared.
Who ever buys this rig is going to be one lucky son of gun.
I hope all is well Steve!
-Anders
gp01
