M416 LED tail lights
brian90744
American Trekker
I needed to upgrade the rear lights, LED was the only way. see pics
brian90744
American Trekker
4" round 12 LED lights
I used 4" round 12 LEDlight from EBay $10.00 each,=
Pop the red lens off . (BTW) the more LED's in the light the better. remove all the stock light brackets from inside the trailer light, leave 5" of wire to connect to the new LED's. Dremal Grind about 1/4" of the fins in the housing to fit. test fit, I used silicon to hold in , let dry over nite. Don't forget the ground wire. Details about LED 4" Red Round STOP TURN TAIL Light w Grommet Pigtail for Truck Trailer See E bay.
Pic' may help=
brian90744
American Trekker
Purchased from EBay seller "24hourskymall" Also check eBay item number:370872743860. And Amazon has them also=AutoSmart KL-25108RK 4" Round LED Stop/Turn/Tail Light Kit with Red Lens
Do you have a link to the EBay seller?
brian90744
American Trekker
4" round 18 LED's
found red LED lights with 18LED;s on EBay -=eBay item number:131082362878 just FYI=brian comes with NO wiring harness
Kevin Braun
Mountain Biker
Nice job! I've been looking at ways to do this and even had those lights on my amazon list for months, but never thought of taking them apart!!:clapsmile
brian90744
American Trekker
Kevin.
just insert screw-driver between the red lens & white body and prior off . and you are all set.
brian
brian90744
American Trekker
space out light from M416 body
I found the light housing on the M416 rubs on the tub body, I spaced mine out 1/2" with nuts between the bracket and frame. See pic
brian90744
American Trekker
18 LED problem
I ordered an 18 red LED light from EBay for testing =seller (trailershoppe in PA) Came without wire harness, and I had to Dermal the red lens off. I cannot recommend,.
Just FYI=brian
