E450 transmission parking brake???
Had a quick question regarding the parking brake that can be found on the rear of the transmission of my 2005 E450.
Went to remove it last night and had no luck in doing so.
From everything that I could find online and by looking at it, it looks to just bolt onto the tailhousing of the trans with 6 bolts. Its not attached the the trans crossmember.
I know there is a dowel pin at the top but I could not get the 2 pieces to seperate! I used the standard technique of using screwdrivers as wedges and hosing it down with penetrating oil.
No doubt the aluminum has oxidized some and its dragging on the dowel pin but besides putting more ******** into "whacking it off" any other suggestions? Have I missed some hidden bolt?
I do not want to damage it or the trans.
crostopher
