Prefilters have a minimum air flow below which they do not do their job and a maximum airflow above which the prefilter restricts air flow to the engine. If you are thinking of a prefilter you need to calculate your engine's airfow between idle and your highest normal driving speed and pick a prefilter (and a filter) based upon your engine's actual requirements.
Fit too big a prefilter and it does not work properly at low RPM on the trail.
[/CENTER]
TeriAnn,
Nice to see one mounted up. When driving in the desert for several days I end up needing to change my air filter at least every 5 or 6 days if I want to be kind to my engine. I also wouldn't mind getting the intake a few inches higher for water fording.
After doing lots of research on the best precleaner I decided on the same one as you. I did a search on good ol expo and was so glad to see someone else using one of the Topspin precleaners.
I just got mine.
For other folks looking to figure out their CFM's check this link out:
http://www.centriprecleaner.com/themes/centriprecleaner/cfm-calculator.htm
I first had to calculate the cubic inches from liters which Google did for me nicely. I then inputted the volume efficiency based on this little chart.
4 CYCLE ENGINES
C.F.M. = C.I.D. x R.P.M. x Vol. ******.
3456
VOLUMETRIC EFFICIENCY:
Diesel Naturally Aspirated = .85
Turbocharged = 1.60
Turbocharged - Aftercooled = 1.85
Gasoline up to 2500 r.p.m. = .80
2500 to 3000 r.p.m. = .75
3000 to 4000 r.p.m. = .70
Then I put in the normal cruising offroad RPM's and the max RPM's I usually see when accelerating. That showed me which filter I needed and bam bob's yer uncle.
BTW, I found them on Ebay for a price that appeared to be 30% or more less than some of the tractor sites. When I get around to mounting it I'll post some pics.
