SOLD: 1995 Land Rover Discovery 1 300 TDI Diesel 5-speed Manual 7 Passenger NC
WolfRubicon
*******************SOLD!************************** Going to a good home!
1995 Land Rover Discovery 1 300 TDI 5-speed manual (7 passenger). Arles Blue w/ white roof, Gray interior. A/C is fully functional after swap and is cold! This Discovery 1 has a new re-stained dash w/ no airbags, no ABS. The gauges read in KM/H as this has all the correct glow plug lights and no unleaded logo. This Rover has ZERO rust issues. The doors and frame have been coated with Crest Honey Coat. Truck was repainted in 2012. No body damage or dents, and again, no rust. Headliner and interior are in great condition. This truck has no sunroof (bonus as it has no leaks)! It has a cloth interior and 94 style manual seats.
Have all documents on the conversion. Some of photos show truck with white wheels, they are now a semi-matte black to match the hood blackout decal.
Professionally converted in 2011 from V8 to 300 TDI by Cityside garage located in Holliston, MA. http://www.citysidegarage.com/ TDI had 78K when installed and has covered just over 22K since conversion.
Engine:
New Dayco Timing belt kit, new injectors, glow plugs, glow plug timer, new tensioner bearing, water pump, lift pump, PS pump, power steering box, all belts and hoses were replaced, silicone turbo hoses, new rear main seal and front cam seal, new battery June 2014, rebuilt injector pump, rebuilt alternator, full stainless steel exhaust, new engine and gearbox mounts. New Mantec snorkel!
Drivetrain:
New rear U-joint style driveshaft. Rebuilt double cardan front driveshaft with aluminum adapter. F swivel balls filled with one-shot grease. All new wheel bearings, races, and hub seals, freshly packed. All but rear shaft were done Spring 2014 along with brake overhaul.
Gearbox:
New clutch kit, resurfaced flywheel, throw out bearing and fork lever.
Brakes:
All new remanufactured brake calipers, brake rotors, and Ferodo brake pads on all four corners. +40mm stainless steel brake lines F&R. Fresh fluid. Brake overhaul done Spring 2014.
Suspension:
Brand new OME Heavy Duty springs F&R, new OME Nitrocharger shocks F&R, new F tubular shock towers, new Terrafirma lowered rear upper shock mounts, new F&R spring retainers, all installed Winter 2013.
General:
Safety Devices low profile roof rack w/ custom matte aluminum diamond plate (removable)! New rear door ladder. 5 new wolf military steel wheels, BFG A/T's 235/85R16. Rovertym rock sliders with extra side step and Rovertym winch bumper w/ steering guard. UK spec trailer mount (not currently installed). New gaskets on rear windows. Saudi Spec Front Grill! Hood blackout decal. Rear CB antenna mount and RG-58 coax ran to behind passenger dash, ready for radio/antenna install.
Interior:
All 5 doors have new actuators. Front doors have new window lift arms. Both front seats have new Exmoor Trim foam. All door handles have been replaced. New dash was installed and re-stained due to typical dash curl. Full set of matching factory seat covers. New ignition key tumbler, custom rear load space mat, and new rear aluminum door panel. New clutch and brake pedal pads. Entire floorpan has been covered with Monstaliner in matching grey color.
Lots of extra parts included: a set of matching front seats no rips or tears. All 4 door panels, all 4 windows and rails etc. rear wiper motor and arm, door actuators, A/C heater controls, plastic sill trim, door locks and hinges, extra switches and dash parts, etc. Have receipts for pretty much everything!
Photo Apr 02, 5 32 04 PM.jpgPhoto Feb 12, 4 17 01 PM.jpgPhoto Feb 15, 3 04 29 PM.jpgPhoto Jul 22, 11 31 18 AM.jpgPhoto Jul 22, 11 31 31 AM.jpgPhoto Jul 22, 11 32 44 AM.jpgPhoto Jul 22, 11 33 03 AM.jpgPhoto Jul 22, 11 33 23 AM.jpg
$17,000
wolfrubicon at g mail
Email/PM with any questions or if you'd like to see more photos. I have plenty! Thanks!
unplannedbbq
Met wolfrubicon & took this for a test drive last week.
The conversion looks and feels factory, 5spd shifts smoothly. Heavy, heavy clutch w/ good engagement. Body/frame are incredibly rust-free. Drove around town & on freeway w/ no issues.
Loved the aluminum shooting platform on the rack; ladder/platform did not flex under my 200lb.
Did not test 4wd. Was very impressed w/ the truck & my kids wanted me to buy it.
I was on the fence between buying this TDI vs. upgrading my westy. Decided to show my VW a bunch of love this fall instead of bringing the Disco home. GLWS.
Roverx
Love this truck and wish I could buy it back:) I did the build and Tdi conversion a few years ago before moving onto the next project. Hunter took this truck and made it even better! You will not find very many 300 tdi discovery in this condition. It is top of the line and you will not be disappointed if you purchase this rover. You can easily get into this truck and drive it out west w/o issue.
Good luck with the sale. My next project arrives in the driveway in two weeks. The tdi defender is sitting in a barn awaiting some love. Hunter, hope to catch up soon.
Cheers,
Scott
Rovertrader
Supporting Sponsor
Bump for an awesome truck, great seller, and excellent Rover guy builder!!
This is one I would consider buying, rather than building my own, knowing all the parties. You cannot come near duplicating it for the price! Could easily cost double to build IF you could find as good a truck to start the process...
haven
With an odometer that reads in KMs, this sounds like it's not a truck manufactured to USA specs. Where was it imported from? Or did you swap out the dash when you did the engine transplant? I ask because Land Rovers from North Carolina have been in the news lately...
Rovertrader
Supporting Sponsor
Actually, Defenders- specificly- from all over the USA that were pro ported noncompliant as imported by a certain importer in NC were in the news lately. Question is how does that pertain to this NAS titled Discovery??
ZG
Busy Fly Fishing
Conversion completed in the states
Racingdad
So there is no requirement for the instrument cluster to be in MPH rather than KMH for cars certified to be here in the USA? When I had grey market cars in the early 80's I had to change out the instrument cluster back then.
Racingdad
Unfortunately for those of us in emission controlled locations non EPA certified diesels like the 300 tdi cannot be registered. Otherwise I would dearly love to consider this vehicle! GLWS!
oskarf150
