Bridging a gap?
silvrzuki77
explorer
Need help with a clean way to bridge the fender and body gap?
Thanks!
Ozarker
Put a weather "weld" strip in, like the rubber stripping between a VW bug fender and the body, you can get rolls at a body shop or probably a glass shop, just flat stock with a bead on it, like that used in upholstery on a hem.
That's pretty rough, might just use bondo, sand and paint too.
silvrzuki77
explorer
Sorry guys tapatalk for what ever reason just showed me people responded!
Boog2001 yes I do, its under UAV TT.
Thanks for the advice guys! I slapped the 35's under the trailer I might need to trim the fenders down more and then decide on a filller
Decosta18 bridging the gap is simple terms is dividing the relative thermal distance minus hydrogen ion couplers x the metric equivalent. Thermal expansion is negligible since no heat conduction is known 😜
silvrzuki77
explorer
Southpier... That is some great product! I dont have a lip on the exterior body. Its mostly flush with wood framing. So it eliminates me from using trim seal. Which suck cause they are nice
jordanP13
