G500 - Tire Sizes/Lift Height and Computer Reprogramming
chris505
Did you try barely touching the brake pedal with your left foot in those corners? Energizing the brake lamps disables ESP...
otiswesty
Regular guy
Another option is to put in an ESP kill switch for those curvy back roads. The stock switch will work for speeds up to 35 MPH, but the center locker switch will disable at any speed. The trick is to run a trigger line to the locker switch pack ESP output. Karl of Gwagen Accessories fame has done this and a couple of others as well.
darrylkd
