Edgestar freezer/fridge 63 qt
morrisster
I'm selling my Edgestar fridge/freezer. 63 qt size. A few years old and very light use. I just plugged it in in the garage and the temp went down to -4. This is a great fridge, only uses 70 watts to run, and doesn't require a huge spike in amps to switch on. The 12v cord quit working shortly after I got it, and I didn't bother to look up how to fix that, instead choosing to run it off an inverter using the 120 plug - which works just fine. I subsequently lost the 12v cord, so it doesn't include that.
You get the fridge in excellent working shape, and the 120v cord.
Sold
WOODY2
FYI when it runs on household current but not 12 volt it's usually just a loose wire inside the cover plate. The unit I believe actually runs on 12 volt but has a built in inverter to convert 120 to 12 volts. May help with your sale. Good luck
morrisster
Thanks woody2, I had the fridge serviced and there wasn't anything wrong inside with the electronic controller or anything (no loose wires) - the 12v accessory plug from edgestar is garbage and from my research done more recently - I discovered that it most likely rattled apart and self destructed. I could make a new cable for the buyer if it was desired. I had a permanently mounted 120v inverted powered plug in my vehicle so it wasn't a big deal for me. A new cable from edgestar can be obtained for like $30, but I'm sure it will be as fragile as the original one.
zhukoveli
