Toasty
It has been brought to my attention that my build thread recap has a bunch of X's where pictures should be. Yes i know typical 4x4wire.com but it's actually my fault because i've moved pictures around and never updated the links. I realized i don't have a build thread here so i figured i'd just revitalize my build thread and upload the pics to Exportal so they are here forever. I'm actually in the process of taking this build a step further so i'll just pick up where i left off. Enjoy
So i bought my '99 Montero back in '05ish completely stock and never been in 4WD, I purchased it from a dealer on a friday night then took it home and removed the running boards and slapped on my Outerlimits4x4.com sticker. That following morning i hit the trail...
The trail hit back and i was left with a bent driveshaft and a crushed catalytic converter, I think maybe days later i got it up on some 33's and just rocked the bum drive shaft and cat for a while.
From there i went with a complete new exhaust from the manifold back (magnaflow cats and muffler) I also decide i should protect my investment with some new skid plates. At the time i went with 1/4" plate except the T-case which i did in 1/2" and the front skid in 3/8" because 1/4" can't hang in those places. Note: I've since moved on to thinner ballistic grade armor for fronts and centers to save weight, those can be made from 1/4" or probably even 3/16" (yes it's that awesome)
Somehow the 33" Dunlop M/Ts i bartered with a friend for popped before ever making it to the trail, so i opted for some new 35x13.5 Toyo M/Ts on 10" 3.5" BS wheels. I had to roll the fenders a bit and remove my bumper corners to make them fit without a lift. In the rear i just cut off the quarter panels and trashed the stock bumper, I made some cheesy sliders and rear bumper (another one of my early fabrication attempts as a teenager). It turned out that 4 wheeling was a rub fest without a lift so I invested in a 2" body lift and hit the trail again. If only i had done the body lift before the sliders and cheese bumper
Tired of running over my bumper ends i decided to build my own bumper, I had just graduated from shop helper to helper/welder so i had access to more tools and things. I made templates for all my bumper pieces out of cardboard and scanned them into the computer, the shop CAD drawer guy was nice enough to draft and cut the pieces out for me. From there i assembled and built the bumper myself, i also cut up and rebuilt my front frame section to be stronger and higher while maintaing the stock winch location just in case i get a winch one day. So finally no more rubbing, the bumper was the last thing, and it only rubbed when it got bent into the tire. Now i can stuff the tire fully and not hear a bunch of noises. Right around that same time i got the first Airtech snorkel in America... (anyone know how that played out?)
I needed to wrap up that front end so i built the front skid and finished the winch plate, I made some bumper hoops from an old Bronco rollbar and picked up a winch from a neighbor for $50. The front two winch bolts are countersunk to keep them from getting sheared off by rocks, this was a regular problem with my skid plates.
With all the extra weight i really needed some gears, I picked up a front axle assy from an AWD Montero Sport with 4.90 gears, got a smoking deal on a full Detroit locker and installed that and a new rear 4.90 gearset. Now the truck was locked front and rear with the correct gearing for my new tires, back on the trail it just wasn't enough and the truck still had to work extra hard to get where i wanted it to go and the more i made it work the hotter it ran. Ordered and installed Marks4wd 3.15 gears, they pretty much install themselves yeah there's a little grinding inside the case you need to do but it's very minor and a baby could do it. Either way it was too much for the average consumer to handle so Mark discontinued these gearsets and replaced them with the much easier to install 2.72 gears
Now with extra crawlability some things needed to change, i boatsided the rear quarter panels.
I capped the openings with 1/8" steel and ringed it with 1"x1/2" flat bar i then filled the space inside the panel with foam.
