Conqueror Compact Water Pump Retrofit Help Needed
highdesertranger
what are you asking about? the water pump? the water pump will work fine. those quick disconnects mounted low on the tanks is asking for trouble they will leak eventually. highdesertranger
XJBANKER
I like that setup. I don't see the purpose of the quick connection underneath. Why not leave it hooked up all the time. What I would want though is some way to drain the tanks. Now I open the valves and drive away. A good way to dump a lot of weight when we don't need it anymore.
Goldenbora
