Good Evening Chevy Adventurists
Original Owner
2003 Chevy Silverado / 2500HD Duramax / 4WD / Crew Cab / Long Bed
I am just about done with the mod of a custom utility bed to fit my FWC Grandby. I will post a build soon. I have a few suspension issues and wheel & tire decisions to make. Positive input is always good on that issue. At this time i'm running stock suspension with front level kit and air bags in rear.
This truck is no longer my daily driver. 212k miles and still running strong. Has been used and cared for well and to its max at times. It is now hopefully going to be now just an adventure / exploration rig. Lots on the want and to-do list. as cash comes in mods go in to truck and camper.
Most of my travel to this point and most likely the future, have been light to moderate off road to get to locations.
Tire / Wheels:
16" stock alum wheel with mich ltx m/s2, 285/70r16 e rated. Strong enough to carry as is empty with camper, 3750lbs @ 80 psi. This is second set of these tires and i have been extremely happy with them. last set 70k miles. A lot of empty wheel well space now with new bed that i would like to fill. Dually adapters wheel and tires or widest tire on deepest neg offset rim i can find. dont really know which way to go. pros and cons??
Suspension:
Dont really want to lift truck but not opposed if need.
As is with no air in bags, she sags. With air @ 80 to bring just above level, she rides rough. 65 seems to be ok, but a lot of sway and lean with bounce.
options i have been contemplating:
going to Deaver and replacing spring packs or National spring rebuild
Front and rear sway bars
Other ideas????
before
last fit check before linex
hard to see but look at wheel well space
look forward to feed back
thanx john
Original Owner
Tire / Wheels:
Suspension:
Other ideas????
before
hard to see but look at wheel well spacelook forward to feed back
thanx john
