EarthCruiser
G`day Andrew
What engine is in your truck? If you need a good FUSO contact in Mongolia we can help.
G`day Andrew
On my 2007 FG...
My truck has been giving the P1335 error for as long as I have owned it, with no discernible effect.
I wrestled with low fuel pressure due to bad/contaminated fuel for a while so have some experience.
2000 rpm is the computer limiting the truck (it's in "limp mode"), which low fuel pressure can certainly trigger.
I've found that the low fuel pressure fault will self clear when the problem is corrected, so if you are still getting the code it is probably still an issue.
.... Just to confirm, are you saying there is no way to clean the common rail pressure sensor?
I think the problem is too little fuel. The temperature has varied a lot, from 30deg in the south of China to 0 deg here.
I was having overheating problems in the SE Asian countries, so I took the thermostat out, (though it does seem to work OK) and a bigger radiator was put in. I do think the issue is a fuel one, though new fuel has been put back in. I never drained the tanks though, (I have 2). One thing I am also concerned about is that the 2 tanks were actually taken out and the fuel gauges were adjusted in Laos, (I was having issues with them). I can't see any fuel leaks, but there is a possibility a fuel line has been pinched, though that should've become obvious by now. I did smell and see diesel on the rear mud guard one day and I thought there was a leak. I cleaned it and I never saw it again.
I will have a look at the wires tomorrow.
Thanks for your help.
