Tools to keep in the Disco II
beastpath
Hi all,
Would like input on what tools I should keep in the Disco II at all times. Would like to keep it sensible and compact (to fit in the compartments in the back). I did some searching and found some lists, the one here from Pangaea Expeditions seemed reasonable, although I would probably cut out the air tools and not be so specific with brand names. Any additions Land Rover guys think are essential to have?
Craftsman Professional metric ratcheting wrench set (8-19mm)
Snap-on ratcheting screwdriver
15lb Powertank with tire gauge
Pneumatic 3/8 impact gun
Snap-on assorted screwdriver bits
SAE wrench set
Metric wrench set (with extra 10mm, 13mm and 17mm wrenches)
1/4", 3/8" and 1/2" socket wrenches
Hand drill
Corresponding standard and deep well socket sets
Spare bulbs, fuses, belts and hoses
Spare fuel filter
2 quarts of oil
1 quart of 90wt gear oil
1 quart ATF
1 roll of Rescue Tape
Gaffers Tape
Pry Bar
Snap-on wobble socket extension
Latex Gloves
David Harris
Looks like a good start. I've found it's best to do all the work on the truck with the tools you have in it. Every time you do a repair or maintenance step on the vehicle add the tools you used to the in vehicle kit and then continue to use that tool set from then on. This way you are assured of having the required tools for any likely repair on hand when needed.
You'd be surprised how few tools you need to keep these trucks going. I just carry a small basic tool kit in it's plastic case, a small tool bag, and a medium plastic tool box for electrical and a few bulkier items.
Quest4ADV
This should cover most of it:
getlost4x4
Barring catastrophic failure.
Metric Ratchet Wrenches 8mm through 19mm
Sockets 8mm through 19mm
Extensions
Some Screw Drivers
Vice Grips
Allen Keys
Torx Head for Ratchet
Milwakee 12V Impact Ratchet
Land Rover Jack
27mm Socket for wheel lugs
evansjoem
I would hold off on the fuel filter unless you plan on dropping the fuel tank out in the bush. U-joints are a biggie to carry
beastpath
Will keep that in mind! So far haven't done any repairs (yet).
Nope, that set is missing a pozidriv #3 (every LR owner should have one)
The screwdriver or the bit?
Extensions
Some Screw Drivers
Vice Grips
Allen Keys
Land Rover Jack
12 volt cordless or corded impact? any recommendations?
Good point. Not likely I would be doing that. Easier to get pulled out.
Thanks all, great input so far. Trying to keep things simple and organized.
Rovertrader
Supporting Sponsor
shop manual, OBD II scanner, and the thin walled driveshaft socket with built in extension- oh, and a hub socket.
CDL comes in real handy as it allows 2wd vs no wd...
proper4wd
Pozidriv #3 screwdriver is sufficient... I have a "custom" one that I made using a stubby handle put together with a normal length blade. One of my favorite hand tools. It fits in small places due to the small handle, yet reaches into difficult spots with the longer blade. You can take apart just about the whole interior on a DII with this and a panel tool.
Lono
Aren't the bolts on the front end of the rear propshaft 9/16th or something oddly non-metric like that? I found that out the hard way on the side of the road when my flex-couple bit the dust on 91 in VT when I tried to disconnect it.
flipstick
