The "Monster's" tail build thread
AZ_Ray
Making progress
Here's my homemade custom superduty trailer axle
Here's the axle going under the frame, no leaf springfs yet. Trying to figure out total hieght needed for them.
Looks cool just the frame behind the X
But had to see it with the body on it, far from being ready for the road but it's a huge stepping stone.
BTW frame ground clearance currently is 30" and axle is 16" of clearance
AZ_Ray
Haha, guess I uploaded to many pics at the same time to 3 different forums, used to much bandwidth had to pay for photobucket. Pics can now viewed in the thread, lol
frig84
Love the idea and the build. I was just wondering how you were going to lubricate the bearings on the axle? If you were going to use axle fluid or if you were going to pack the bearings?
AZ_Ray
I am going use gear oil. I'm having
A shop build custom axle ends with pop out plugs like semi trailers have. Just so I can keep an eye on oil levels and quality.
Also going to install a drain plug for the whole axle housing.
frig84
Just curious not a bad way of building an axle. I usually have access to housings that have gone bad. Spun carrier bearings and damaged pinion areas. Thanks for the information.
AZ_Ray
It can only be done with a full-floating differential.
frig84
I had thought of just putting a drain port on the bottom of the tube and a fill port on top, and filling about a quarter of the way up.
AZ_Ray
The trailer should be making progress here shortly.....everyday I've been getting Bowes in the mail or the wife has been picking up parts for me. Pic will be coming soon.
rumpityz28
