Just bought a 3rd Gen!
MascotRejct
Hey guys,
So after looking on craigslist for a couple weeks. I pulled the trigger on a 2001 limited 3.5L with 209K miles for $3642 out the door. I've been mentally making a list of the maintenance that I need to do before I am completely satisfied and can move on to the aftermarket stuff (That list is MUCH easier to make!). So far I have this:
- Replace timing belt and water pump
- Replace valve cover gaskets
- Its throwing two codes that both seem to indicate it needs a new O2 sensor (P0125 and another one saying it is running lean in one or more cylinders)
- New idler pulley - one of them on the upper driver side inboard of the valves is squeaking a little bit.
- Oil change just cause.
- Maybe ATF? Not sure what the life is on the fluid in there now...
- New wiper blades, the current ones blow.
- The passenger front brake squeals after i let off the brake pedal, and the pedal itself seems to stick a little bit before actually releasing. Any ideas as to what that could be? Master Cylinder or calipers?
Can you guys think of anything else I should do while I've got it torn apart? I'm debating on whether to do the head gaskets just cause I have a another vehicle at the moment that I can use, but I figure if I do that, then I might as well get a valve job and the heads machined and it seems like it kinda adds up fast...
Also, those of you that have performed these things before, any recommended brands to use, or where to buy? Are there any manuals online that you guys know of? Any help would be greatly appreciated!
I will post pictures soon, i'm just not feeling all that well right now. Its stock, silver with black leather interior, with minor dings and bumps. All in all, looks pretty good for a 200k rig.
Thanks guys!
Edit: Forgot a couple things:
- The steering wheel itself kinda sounds like a leather on leather rubbing sound when I turn it. It's not bad at all, just want to see if anyone else's has done that before and what they did to get rid of it.
- I know the Cam (crank?) bolt on gen 2.5's is a problem part and should immediately be replaced, Is it a problem on the early gen 3's as well?
MascotRejct
So currently sitting in my rockauto.com cart is this:
Part Price Quantity Total
2001 MITSUBISHI MONTERO 3.5L V6
Engine : Timing Belt Component Kit
DAYCO # WP320K1AS Water Pump Kit with Seals
Includes: Water Pump, Timing Belt, Hydraulic Timing Belt Actuator, Camshaft Belt Tensioner, Camshaft Belt Idler, 2 Camshaft Seals, Crankshaft Seal, Pre-Assembly Seal Lubricant; Water Pump Driven by Timing Belt, Interference Engine A
$119.79 $119.79
Ignition : Spark Plug
CHAMPION # 9202 CHAMPION IRIDIUM (Rebate/Promotion Available!)
Gap .044
+ Sold in packs of 4; Price reflects cost of each individual item, not the pack F
$4.87 $19.48
Gap .044 D
$5.50 $11.00
Engine : Intake Manifold Gasket
FEL-PRO # MS95709 Set
Lower set; Upper set incl. F
$10.82 $10.82
Engine : Valve Cover Gasket
DNJ ENGINE COMPONENTS # VC130G Includes Grommets and/or Spark Plug Tube Seal Set
Set E
$11.88 $11.88
Engine : Timing Cover Gasket Set
VICTOR REINZ # JV5134
Oil Pump Gasket Included; Sealant Not Included; Timing Cover Gasket Material: Paper D
$17.21 $17.21
Cooling System : Thermostat
MOTORAD # 302180 Standard
Temperature: 180F; OEM Recommended Temp D
$10.03 $10.03
Cooling System : Temperature Sender / Sensor
BECK/ARNLEY # 2011220 {#2011627}
w/Gauge C
$6.56 $6.56
Belt Drive : Belt
DAYCO # 5070950 Exceeds OE Specifications Effective Length 95.08 / Top Width .96 / No of Ribs 7 / Thickness 0.169 Poly Rib Belt, Premium
Main Drive F
$21.79 $21.79
Cooling System : Radiator Lower Hose
GATES # 22657 {#MH2657} 1-5/16" x 35" Does Not Contain Spring Molded Coolant Hose
Lower
* Stocked in outlying warehouse--shipping delayed up to 1 business day D
$11.76 $11.76
Cooling System : Radiator Upper Hose
GATES # 22656 {#9289, MH2656} 1-11/32" x 17 19/32" Does Not Contain Spring Molded Coolant Hose
Upper D
$9.78 $9.78
Ignition : Spark Plug Wire
NGK # 7005 {#8806, ME94} NGK Wire Set
Magnetic Core Wires; SPARK PLUG WIRE SET B
$43.79 $43.79
Wiper & Washer : Wiper Blade
BOSCH # 4820 Evolution
Front B
$8.50 $17.00
I will also be adding an O2 sensor to hopefully get rid of the P0125 code that popped up on the way home from buying it.
Can you guys think of anything else I would need? Thank you!
jlocster
I'd be very careful to get NGK or Denso iridium spark plugs and stay away from the other brands. I would also add rear cam o-rings to your list. I'd recommend you buy OEM Mitsubishi for these as well as for your spark plug tube seals, cam seals, crank seal and valve cover gaskets. The aftermarket rubber parts will get you by, but the OEM parts are superior.
Congrats on your purchase!
MascotRejct
Thanks man! I'm looking forward to it! It's amazing how much truck you can get for the money on these things. Leather, seating for 7, and a center diff locker for less than 4k? That's nuts.
MascotRejct
Pictures!
Here's the pictures of the new rig guys. Hopefully my parts will be here by the end of the week, and I can get it torn apart and put back together this weekend. Then, once I get a job, I can grab an OME lift and bigger wheels.
jhill15
That a pretty sharp lookin rig man! I cant wait to see some pics of the tear down and then back together!
cnutco
Plus one on the NGK spark plugs!
Very clean truck! Even though she has 200K on her, she looks great!
Inyo_man
Don't piss down my back and tell me it's raining.
Great looking rig!
I hope it brings you many miles of enjoyment.
Ditto the OEM seals and NGK plugs, I'd also throw on a fresh set of wires.
Cheers
Henrybrowne
