1994 FZJ80 Land Cruiser for sale in ARIZONA
SALE PENDING SALE PENDING SALE PENDING SALE PENDING SALE PENDING
Looking to let go of our 1994 FZJ80 LandCruiser 80 series. I've been slowly building her up over the past few years for both camping and overlanding but since I
became ill I'm not foreseeing us using her so often.
The vehicle is in Great condition, absolutely no rust, never been in a collision, runs great with no hiccups. Transmission and center diff run
smoothly, suspension is awesome and the vehicle has no wiring issues. Original paint but I did paint the bonnet and side mirrors in Grey.
All windows/actuators work good, Dashboard is perfect still soft with no cracks.
This could be the perfect turn key rig for someone that whats to get into the overlanding/camping world quickly.
Asking $34k OBO or Trade for a late model Caterham 7 300R or similar (I am quite flexible on the price)
Contact: Clayton at 626.379.7221
If you have any questions please feel free in contacting me anytime.
our original build thread.
http://www.expeditionportal.com/forum/threads/75020-Our-1st-80-Series-build
The Shake Down:
Oem lockers with center differential lock switch
Complete engine rebuild w/ oem parts/gaskets (2012)
Old Man Emu HD shocks & springs 3" lift inc. adjustment brackets
30mm polyurethane rear spring spacers
295/75/16r lt Toyo AT2 x5 (New Tyres, less then 2k road miles)
Factor55 winch pull
Warn V10000 winch w/ synthetic rope
ARB bull bar front w/ grip tape & limb riser mounts
Anderson 175 amp power plug (front bumper)
Front D shackle in hot Pink mounted to Factor55
Extreem Air Magnum (under drivers door)
4lbs air tank mounted in (front bumper)
Air coupler mounted to air tank
Daul battery system w/ IBS digital controller
Slee Offroad washer fluid relocation bracket
Limb risers front bumper mount to roof rack
Stainless brake line set front and rear
Baja Rack EXP roof rack
Awning 7' (passenger side)
Kaymar rear bar w/ tyre carrier, Chuck box & opt. jerry can carrier
160 liter aux fuel tank w/ factory Y filler neck (44gal)
Maxtrac safety Orange
Trasharoo OD Green
LED work/flood lights 18w 6LED x2
RTT 1400 Camping Lab (roof mounted)
Safari snorkel system
Rear facing work lamp Kaymar
No leak tyre stem caps
Back up Deka battery ETX16L
Roof mounted 1720 pelican w/-
Solar 15w hard panel w reg.
YETI bottle opener/Hitch cover
Rear bumper mounted Pelican Chuck Box
Partner Steel 18" two burner stove
5LB Propane tank
21" LED bar 10w Cree LEDs 120watts
Wagongear rear tail gate extra storage lid.
Passenger quarter mounted prep table (not installed) parts only
Interior:
54" storage slide box
27gallon fresh water tank
.75" thick rear platform rubberized
Aluminum tie down rails x2
Tie down adjustable loops x6
Subaru WRX seats mounted front
Yaesu ft8800r de-chipped
38" short wave antenna
18" short wave antenna
Kenwood radio w/ Bluetooth
Daul marine USB .2amp plug (center console rear)
12v acc power port center console
Boston 3.5" rear door speakers
Kicker 6" front door speakers
Weather Tec rubber all weather mats
Buss breakers replacing oem buss fuses
LED overhead lighting
Rear tail gate 15 LED strips x2 National Luna
Broadway rear view mirror
SPA fire extinguisher with mount
Forward platform box/water closet
Water pump Sureflow auto on off
Shower system with hot cold mixer
Fridge unit National Luna split50
NL Fridge quick release plate
Custom mounting plate for fridge
Anderson Power Pole port 12v acc x2 (rear)
12v acc power port (rear)
Rig Runner fuse block w/ 5 outlets
Hella LED map light (rear)
Two way winch switch Int. for winch control (not connected)
Compressor switch interior
OEM replaced parts:
Valve adjustment Oct. 13th 2013
Oil change GTX 1030 June. 2014 (Oil Can Henrys)
Fuel filter oem 2013 (OEM Toyota)
O2 sensors x2 oem 2013 (OEM Toyota)
U joints x4 2012 (Napa Autoparts)
Front & rear brake pads oem 2012 (OEM Toyota)
Check Valve oem 2012 (OEM Toyota)
Plug wires oem 2012 (OEM Toyota)
Dis. cap including rebuild oem 2012 (OEM Toyota)
Vacuum lines large and small 2012 (OEM Toyota)
Water hoses oem 2012 (OEM Toyota)
Air filter 2012
Spark plugs oem 2012 (OEM Toyota)
Front window seals oem 2012 (OEM Toyota)
Dash board oem 2012 (OEM Toyota)
All dashboard & switch bulbs oem 2012 (OEM Toyota)
Belts alt & compressor x3 oem 2012 (OEM Toyota)
Front and rear fender flair rubber trim 2013 (OEM Toyota)
Extra Bits and Pieces:
Power Pole connectors
Power pole 4 splitter
100 amp breaker for compressor
50 amp breaker for rig runner accessories
Replacement breakers for 10/15 amp fuses
Pelican 1650 seal 2013
cliffi
Nice build! A few questions:
1. RTT - included?
2. Air Conditioning - front only or front and rear?
3. Would a jack-all jack fit under the bed / beside the drawers or do you have a mount for one?
Thanks
Thanks TEXAS1880,
Thanks ROAMINGAZ and yes, Off Grid Mag. did a cover on our truck earlier this year
Thanks CLIFFI, RTT is included the A/C is front only and a Hi Jack should fit in cabin with modification but I do not belive that one would fit under the bed.
Thanks Again
1. RTT - included?
Thanks
Thanks everyone,
After a long dealing with my ailments we decided to let go of our beloved LC80 as that we did not see any possible way for myself to take the family out or even get behind the wheel in a long time. Even though I've never been a big poster I enjoyed my time on Expo reading about everyone's builds and adventures, it's made these past couple difficult years a little more enjoyable.
Thank Again everyone and I will still be visiting frequently just not much to share anymore.
Clayton M York
Clemtiger84
