Built a bed rack for my father's Tacoma
dtc81
My father recently bought a 2009 Tacoma TRD Sport, which is his daily driver. He does a lot of camping and backpacking, and is a woodworker by trade. He had dreamed up this idea of a roof rack that would allow him to carry long lengths of material, be able to keep his Truxedo tonneau cover, AND make a canopy so he could have "dry" shelter if he wanted to sleep in the bed of the truck. Well there we couldn't find a rack system that allowed all of those options for a reasonable price, so we decided to build our own.
I do a bunch of hobbyist metal fabrication (built all the bumpers/racks on my 4Runner) and have been looking for an excuse to buy a tube bender, and this was the perfect project for it. My father's friend is going to sew a waterproof canopy that will slip over the rack system, and provide a reasonably dry shelter. I'll be sure to add those pictures when he gets the canopy finished!
Fitting tubes (made a jig for the drill press to bore tubes consistently)
Tacked together
Finished (Besides paint and final mounting)
dtc81
I'm going to drill through the plastic and install rivnuts in the bedsides. Probably 3per side. I use them at work, and figured they would work well for this application.
Looks awesome! Nice job.
Interested in some of the particulars:
What tube bender did you use?
Size(s) and thickness of the tubes?
dtc81
@team-oomizumi I bought a JD squared model 32 bender, and pulled 1.75" .120 wall HREW tube through it. It's an awesome machine. I built a stand out of some material I had laying around, then bolted it into my garage floor. I'm very impressed with the bender.
BrianTN
Looks great. I built something similar with a canvas top and brackets to add a roof rack on top if needed. More pics are in my build thread.
jeverich
Luddite
Looks great!
I've built a few that parallel a design very similar - however, I use the bed bolts as an attachment point since I use mine to hold a roof top tent.
I'm sure you've already got it fastened securely to the bedsides without any issue - but just in case you haven't I'll throw in my .02.
I'd try and use the bed rail system as an anchor point for the rack. I know it may be a pain the butt with the tonneau cover on there, but I'd be weary of using riv-nuts in that application. Don't think there's an awful lot of meat to the sub frame underneath the bed sides on the 05+ Tacomas.
Grizzly's G9513 "T-Nut" is a pretty good solution to fasten to the bed rail track.
Just fabricated this due to being tired of having 20' sticks of tubing jerry-rigged in the bed..
