Truefire
Truefire
Its a custom made, fiberglass, slide-in truck camper that I built out of of Nida-Core composite panels. This unit probably weighs somewhere in the 700 pound range, considering sum of panel weights and resin/cloth used to build. 1/2 ton pickup carries just fine. I have air-ride air bags installed on my rear wheels of my 1/2 ton pickup and have no sway or any other issues when hauling.
Possesses:
- 30 amp-120 volt power inlet
 - 30 amp cable supplied (yellow colored outer sheathing) approximately 30-35' long, in great condition
 - 15amp-120 volt power inlet
 - Water tank fill door on exterior
 - onboard shower that runs off 120 volt shore power
 - onboard deep cycle marine battery that serves 12 volt convenience outlet and lights
 - pigtail to tie onboard battery to truck battery for charging onboard while in transit
 - backup light on rear that can be activated from cab
Camper shower (never used). I never have installed a water tank simply because I have not necessarily needed one.
I built this unit to get me through school at North Carolina State University and have used their shower facilities on campus. As seen in some of the pictures, there is some unfinished sections of the camper interior. I ran out of time during the build and just have never gotten around to that. Just needing some wooden accessory doors installed and a small section of wall paneling. No biggie, I just elected to allow the new owner to adorn it the way he/she so desires.
Will certainly answer questions. Asking 3k for it. It really is a sturdy build. I'm just out of school and will not be using the camper anytime soon.
Thanks, chris
