1st gen coil springs
cr500taco
What's the stock coil springs specs on the 1st gen tacomas? I want to custom order a new set. Also, anyone know where to order them from?
cr500taco
What are you trying to achieve? Do you want a lift spring, stock height...?
I have the Bilstein struts with the stock coils set to 2.5" lift. I need to replace my coils, anyway so I want to custom order the coils 2.5" longer than stock but with the stock spring rate, since the Bilsteins are made to work with the stock spring rate. Read that the Eibach springs are too long and too strong for the struts and Bilstein doesn't recommend using them on the struts.
iStan814
