dorifto-san
Creeper
I'll have to look when I get home, I think the bolts are 3/8" x 2", I'll get the rest of the info later on. Was pretty simply to make and had zero flex when I torqued the bolt.
Had to make a tool, it worked flawlessly and only cost $7 to build!
Alright, so here are the specs on the tool: Flat bar is 2"x1/8"x36" (I cut it nearly in half though), also need two 3/8"x2" bolts and nuts. I drilled out the holes for the bolts first, and then dropped a sharpie down the center of the pulley to mark my center point. I used a 1 3/8" metal hole saw which was enough to slide my 22mm impact socket through.
Good luck!
Sweet!!! Why didn't I think of that ages ago? Damn. Do you know how many times I could have used this over the past 12 years of wrenching on my Raider. Holy crap!! Good job Dorifto!
1989 Dodge Raider 3.0L
1997 Mitsubishi Montero 3.5L
I think I have enough flat bar to make you one if you'd like. I'll double check when I get home and let you know this evening. Shoot me a pm and we'll work something out!
