Bilstein 7100 Series Remote Reservoir Shocks
roverbuild
Here is the specs.. All four are the same! They were installed on a 95 D90....
Technical Details
Collapsed Length (IN): 14.21
Extended Length (IN): 24.31
Travel Length (IN): 10.1
Compression: 800
Rebound: 3600
Lower Mount: 1/2" Heim
Upper Mount: 1/2" Heim
Shaft Diameter: 14mm
Cleand
I am interested, but can you show some pictures with them side by side? All four do not look to be the same.
roverbuild
You are right guys! Didnt even realize they were different!
B46-03050R X1 11.57" Travel
AK7112R06 X1 12" Travel
AK7110SB06 X2 10.1" Travel
tgreening
rover I think you might be confusing the snot out of people. You said these were all the same and came off the same vehicle, and yet for 4 shocks you've got 3 different part numbers listed. Can you shed some light on what's what?
roverbuild
I apologize for the mis representation from the beginning of this ad! I have had these laying around and never really bothered looking at the part numbers! I have updated the pics in the craigslist ad and the product specs! I am guessing one of the longer travel shocks had been replaced at some point and they found a replacement shock with relatively the same specs and same valving!
http://raleigh.craigslist.org/pts/4873086478.html
B46-0350R 1 Shock
Body Design 46mm ID Smooth Body(Non-Coilover)
Boot Included No
Collapsed Length(in) 19.53
Collapsed Length(mm) 496.0
Compression @0.52m/s 800
Extended Length(in) 31.10
Extended Length(mm) 789.9
Finish Electroless Nickel with Clear Powdercoat
Internal Design Monotube
Lower Mount Type 1/2in Heim
Rebound @0.52m/s 3600
Reservoir Yes
Upper Mount Type 1/2in Heim
AK7112R06 1 Shock
Compression: 800
Rebound: 3600
Collapsed Length: 19.61
Extended Length: 31.34
Reservoir: Yes
Reservoir Type: Remote
Body: 46mm ID Smooth Body (Non-Coilover)
Finish: Electroless Nickel with Clear Powdercoat
Coilover: No
Spring Seat: No
Manufacturer: Bilstein
AK7110SB06 2 of these Shocks
Compression: 800
Rebound: 3600
oskarf150
