stainless brake lines interest
tlr
I talked to a race shop today that can make brake lines to replace all 5 rubber lines with braided stainless. Would anyone here be interested in a set? Currently looking at a set for my gen 2.5 I've also read it will eliminate the pulsing from the abs.
Thanks
Toasty
The Parker store builds them for about $1 per foot of line and $5 per end, they are better than steel braided automotive lines they have a wrap around the steel to make it tougher and handle higher pressures. MSHA grade essentially
jeep-N-montero
Did you have a set made?
Toasty
They made all my high pressure oil lines with hard to find banjo's and Japanese imperial metric fittings for my turbo and vacuum pump. I asked about brake lines when i was there and the guy said it'll be about the same price as maybe less than the stuff they made me for my engine.
jeep-N-montero
Could you get some definite numbers put together? I'm sure there is demand for a complete set, especially for those with lifts and bigger tires.
tlr
Well I'll be going down there in a week or two to get my lines done and reply here with prices and possibly part number if they supply them. I do have a favor to ask, anyone with a gen2/2.5 that's interested to please check you lines and post here. I have female to female front, female to female rear center and female to male outside rear. All should be m10x 1.0 inverted flare. Now the issue is that a lot of the parts stores list all sorts of combinations for our trucks so I would like to check this.
Thanks
oskarf150
