FG 637 New to forum
Aussie Iron
Now this may or may not cause some debate but as some have a hard time with the colour WHITE, I thought I would try a different approach. I live up here in the tropics and it is the wet season, so a North American urban winter camouflage pattern seemed appropriate. What do you think?
I like it, well done.
Dan.
Raker
Tray Modification
tray removal.jpeg When I was fitting the extra fuel tanks I discovered that the cross members were rusting away. The good thing about having a crane is that I could remove the tray quite easily. Now I have better access to the offending bits.Tray is gone.jpeg
DzlToy
Are both rear axles going to be driven? If so, how? Second transfer case or axle swap or?
In the States, 2.5 ton Rockwells are quite common and make an easy conversion but require significant investment to really make them top notch.
iStan814
