universal suspension seat bases
jeep-N-montero
I have 4 suspension seat bases that can be mounted to any flat surface and flat bottom seat, you can adjust firmness and even lock it into place if you wish. Asking $160 each including shipping obo. These do not rotate. There are 3 in the pictures but the 4th is hiding in the garage. I will get bolt center measurements and post them up shortly.
jeep-N-montero
Seat mounting bolt holes are just shy of 12 inches from front to back and 16 inches side to side, but you can always drill new holes where needed. The floor mounting holes are 10 inches apart side to side and about 8 inches front to back.
addicted56
Do you have a MFG link and specs? My biggest concern is in the later model FJ40 the tank is under and we just don't have the depth for seat brackets. Mine are currently mounted directly to the floor so thinking these will not likely work.
jeep-N-montero
Sorry, no link, but you can bolt these directly to any flat surface.
Czechsix
Watching you from a ridge. In Alaska. I'm cold.
What kind of travel do they have? Are these from HEMTT and LVS's?
AlanMcR
Going from my memory (with a little boost from the seller's handle), these were used for the drivers seat of a Mitsubishi Montero.
I remember liking the system quite a lot, and was ever considering retrofitting my 1996 G with these. The utility of the under-seat storage swayed me away.
AxleIke
Sorry if I missed it, but can you tell me the overall height? I really like the idea, but they look like they might be too tall for my application.
Thanks!
