Finally took my Pop-up/Tundra to the Scales - What a pig!
DVexile
I wish all the build threads here had weigh-ins -- most, though not quite all, look to be significantly over the recommended weights.
This would be helpful. I wasn't interested in a full size truck, just prefer the narrower track and shorter wheelbase of a Tacoma for some of the trails I go down. I've seen plenty of Tacomas with a FWC and started researching that as an option last year. Just *dry* with just two passengers and no baggage at all puts you over GVWR. Never mind people then throw on plate bumpers, a winch, recovery gear...
The other elephant in the room is a fully optioned truck does not have close to the load capacity advertised. Difference between the "specs" which are for a fully stripped down vehicle compared to the door sticker of the truck you actually buy can be over 200 lbs.
I'm building a Tacoma with a Flip Pac and the Flip Pac weighs less than 300 lbs. On a Tacoma that still means wet weight for a week of camping and basic recovery gear is going to creep past GVWR. With a FWC you'd just blow it away by a mile. And yet I see plenty of folks doing that often with even more additional weight strapped to the truck.
Problem is a lot of us pack for "in case sh!* happens"
This seems to be the slippery slope on display all over this forum. Each thing you add doesn't seem like it will take you over, or that much more over, and is of course useful in some imagined situation. The problem is as you add more and more stuff you transition from "in case sh!* happens" to actually "making sh!* happen" because the vehicle is overloaded.
The thing I worry about the most to be honest is that we tend to plan for imagined recovery operations or body damage out on the trail to the detriment of safety trying to get to the trail. Winches, tire chains, jacks, shovels, axes, plate bumpers, sliders and so on. But really, if you get stuck so what? You are in an effing expedition vehicle. If you get badly stuck that is just an "unplanned camp site". You'll be fine, no threat to life or body. You are just delayed and inconvenienced.
But what about getting to that trail? You can be the most careful driver in the world, but unfortunately those around you on the highway aren't. Taking a vehicle 1000 lbs over GVWR with a higher CG out onto a highway full of morons seems like it is increasing the likelihood of a close call or a fender bender turning into something much worse. Death and injury on the highway are real statistically significant threats to life and body unlike imagined survival scenarios.
And of course being 100 lbs over GVWR is no big deal. Perhaps 200 lbs isn't either? Improved suspension and brakes gets you to where, 500 lbs or 1000lbs? Can you really interpret handling in an emergency situation from the handling while just driving around normally? I know a lot of people take the front sway bar off of trucks and feel it handles *better* in day to day driving and of course is more off road capable too. Go do a moose test without the sway bar though and you are on your side or roof. Does anyone really try emergency braking from 65 mph downhill on a 6% grade once they've loaded down their truck?
Agreed. After we scaled, I've been trying to find info on those in similar positions as ours. How long have they gone, conditions, wear and tear, failures, etc.
I'd say we have a good 20k miles at/near our weigh in. We don't baby it when exploring but we don't rock-crawl either.
We've had 1 half shaft issue after visiting the sand dunes (the boot twisted and tore). Brake wear is in check. Tires are wearing a bit faster than we'd like but that's OK.
This is the second part - reliability and wear and tear. Probably really hard to evaluate of course. But certainly upgrades help, but upgrading the "weakest link" is the key and do we usually know what the "weakest link" really is? Or how much weaker it is compared to four other things?
Of course once you make the leap from mid-size to full-size you do have a lot of options for high payload handing so it is a problem that can just be solved with money :) But for a mid-size guy like me weight has to drive every decision. Surprisingly it seems many people plan their trucks like they are one of those USPS Flat Rate boxes in which as long as you can fit it inside it doesn't matter how much it weighs. And I can completely understand why, until I started totaling up what I thought was "necessary" with a spreadsheet I didn't appreciate how quickly and how much overweight you can get!
calicamper
I don't think this is just an expedition peoples thing. I think people read the capacity on vehicles and then think OK its rated to tow 5000lbs so my 4500lb empty trailer will work. We all know it doesn't include option added, water, propane tanks, fishing gear, water, kayak's bikes, golf bags etc. We are as a society in a habit of packing a whole lot of **** when really we probably only need a small portion of it. Also the aftermarket bumpers and gear is cool! But as we all know it can be heavy.
I think what would be interesting in parallel to this is talking about how people pack and what they find can be left home most of the time vs what they have needed nearly every trip etc.
I like packing light everything from trips to Grandma's house to our camping efforts. Our sailing too given every lb is a hit to boat performance etc.
daveyboy
I have a 2008 Tundra DC 4x4 5.7L (Timbrens, Deaver AAL, 275/70/18 E-rated tires) with a Shadow Cruiser pop-up.
On one trip through about 7 Rocky Mtn states (so we had EVERYTHING) including my family, gas, etc, we weighed 7950lbs. The rear may have been a little over the (P-tire rated) axle rating. IIRC it was about 3600F/4350R or around there.
I have at least 10-12K miles with this setup and have had no issues at all--not to mention the guy I bought the camper from had it on a late 90's F150 permanently--and his pickup was going strong at 180K.... .
doctorit
I didn't need to read this thread after browsing the local inventory of Ford Superduty trucks!
I know I'm overweight with my F150 and Northstar TC650. Air bags and E-rated tires make it "feel" ok, but I'm definitely shopping for a 3/4 or 1-ton truck. You read all the stories of "been to Alaska and back with that setup"... I wonder what stories we don't hear?
DVexile
I have the additional problem that my truck lives on the opposite side of the country from me in a storage facility. So I get to fly in a few times a year for my camping trips and don't really have any place to offload or store unnecessary equipment. It pretty much all has to be in the truck all the time for every trip. So that makes the choosing more difficult.
Packing light and careful selection of what is really needed is best understood when you have to carry it all on your back. So I just apply a little bit of backpacker's logic to evaluating what to have. Of course the point is to be a lot more comfortable than a backpacker, so you can't cut back too much!
Here's my list of weight savings measures I've taken for my particular needs:
- Chains: I really only need these to be let onto highways under chain control by the CHP. Since I've got 4WD and M+S rated tires that means all I need to do is show the officer I am carrying chains. So I've got the correct size but lightest weight cable chains I could find only for the rear wheels. That gets me past CHP chain controls. They would also serve as an emergency traction device off road (mud or snow) for a short distance, I would never use them to actually attack a trail covered in snow.
- Water: I've usually got about 15 gallons of water on board for a trip. Since I often drive 300 to 700 miles on highway before actually getting of road I leave the water jugs empty until close to my destination. That's 100 lbs less weight on the highway.
- Hi-lift: I've carried this dang thing for 15 years now and never found a use for it. No more. I've gone with a bottle jack accessory kit instead for my jacking needs. Using a hi-lift as a crappy come-along just looks too terrifying for me to honestly ever expect to try that even if I was stuck. My health and safety is more important to me than my time or money - I'll call in a recovery crew instead.
- Bumper mounted winch: Typically these are used to get *other* people unstuck rather than yourself. Unless you happen to get stuck in just the right way. Come-along is more versatile in solo recovery (my most likely kind of recovery), significantly lighter and the advent of AmSteel Blue has eliminated the whipping hazard of using a hand cranked come-along.
- Come-along: As mentioned, this would be my preference. But still undecided if I'd bring it. I do deserts mostly. Where is my anchor? There are no trees and I typically travel solo. So I'd have also account for the weight of a PullPal if a come-along is likely to be of any use. Again, in the rare case I might need it then I will exchange time and money to solve the problem of recovery at that point.
- Shovel: These are typically the most useful recovery item around and they don't weigh much. Yet I'm surprised many people don't carry a functional one despite tricking out the rig in much heavier ways. I'm upgrading my shovel soon.
- Basic replacement parts: Replacement belts and hoses, various gasket materials, JB Weld, etc. etc. weigh very little and can handle many common mechanical problems. A good tire repair kit is a heck of a lot lighter than a second full size spare (I always carry one full size spare of course).
- Cooler: For very long outings dry ice is a much more weight and space efficient means of storing cooling power compared to an extra cooler full of water ice.
- Camp stuff: Heavier doesn't necessarily mean better. I've got an amazing durable and comfortable cot that comes in at 9 lbs. Careful selection of camp chairs and tables and what not as well.
Anyway, those are some of the choices that have made sense for what I do. Obviously other people have different uses and needs. But would certainly be interested in how others approach the weight vs. function trade offs.
daveyboy
Interestingly, of all the recovery gear you mentioned, chains were the only thing I have NEEDED.
Here is a pic (while still clean) shortly before I was buried to the frame in a snow covered "pond."
I chained up the rear, put it in 4LO and the magic of ATRAC saved the day... .
ExpoMike
Our Dodge Ram 2500 and FWC Grandby, loaded and ready to go, comes in at 8560 lbs. on an 8800 lbs. GVRW. I do try to watch what is added to the truck, to help keep the weight down. Just changed over portable solar panels as they went from 20 lbs. to 3 lbs. It's a lot of the little things that add up.
calicamper
Sounds like GM is going to offer a version of the Colorado without a bed cab only. Listed load capacity is 2200lbs! Now only if Toyota offered a no bed option on the Tacoma then folks might find a flat bed configuration attractive.
question
Weighing is on my to do list....... Not really, I don't want to know :)
Hind sight is 20/20. I should of gone with a queen cab over east/west. This would probably of reduced the porpoising without the Lance struts.
Also the nice counter tops add substantial weight. "Anybody know if aluminum counter tops makes sense??"
Lastly, wood construction is heavier than I thought, specifically my bathroom enclosure.
Having said this, my Ram 2500 diesel handles the load just fine, that is after upgrading shocks and running air suspension @ 90 psi.
Very nice set up, would you be able to post any interior pics, as well what make is your camper.
Thanks
mike
daveyboy
2x4 only... .
MINO
Went back to the scales yesterday in Kingman AZ.
Removed the winter chains, no cats/litterbox, no wife (and overpacked bag, hehe).
Full tank of gas, half tank of water (13 gal). Little food packed.
Front Axle: 3880 (GAWR 4000)
Rear Axle: 4220 (GAWR 4150)
Gross: 8100 (GVWR 7200)
360lbs lighter at this weigh in.
sunnyaz
