DWH got it right. If you bail to lower voltage a half hour after the charge controller sees 14.4V, you're likely at 80%, and certainly not 100%. Charging to 100% at 13.8v would take several more hours, which you probably don't have on a solar system, unless you're not using it. From the manual for my Morningstar controller: "Depending on battery history, the battery remains in the absorption stage for 3 to 4 hours before transitioning to the float stage." That's how you get the battery to 100% with a solar charging system that gets drained every day, and that's why I recommended the Morningstar controller.
Those are the Renogy specs that I found too. The "four" Renogy stages are Bulk/Boost/Float and Equalize. Night is not one of them, since there's nothing for the controller to do. (Good thing it "recognizes" it though...
Note that Morningstar calls the "Boost" stage the absorption stage, which is really more correct. You're trying to get the electrolyte to absorb as much as you can, and the longer the better!
Dropping to lower "float" voltage relatively quickly is ok for a system that sees infrequent use, or if you have too much panel and the ability to get to 14.4V very early in the day, but if you're on it every day, and you don't have an abundance of panel wattage, then you're probably starting every day with 80% battery, which is hard on the battery. (Consider that a solar "day) starts when the sun goes down as far as I'm concerned.
That "kit" isn't horrible, and I do see now that that charge controller has temperature compensation, but it's pretty easy to do better if you have even just a small amount of DIY ability. Read the HandyBob solar pages and use apply what you learn. He's not spewing BS, and he's not making any money, he's just a slightly crotchety older man who knows what he's talking about.
I suppose if you feel that you must buy a kit, that one isn't bad, just be aware that if it's taking you until later in the afternoon to get to 14.4v on the batteries, you may want to add a second panel so you get there faster and have more time to "float" charge the battery to 100%. If you're only using your setup one or two days at a time, and give it days to recover between uses, then the lack of time at "boost" or absorbtion is no big deal.
