3/4ton and 1ton trucks, pivot frame needed/worth it?
TwinStick
https://www.google.com/search?q=wil...niv&sa=X&ei=bEg-Vb-eCIOVNubigJgF&ved=0CB0QsAQ
Is this what you guys are after ?
I ask this because the frame on my truck is one of the reasons I bought it. I have had 1200 lbs in the bed & flexed it (with swaybar disconnected) till i had 1 wheel off the ground & the space between the bed & cab stayed the same top to bottom & side to side. I have a 2008 Dodge Power Wagon. I am certainly no engineer but it seems to me the suspension should be doing the flexing---not the frame. When any metal bends & twists it get inherantly weaker, right ?
762X39
I am certainly no engineer but it seems to me the suspension should be doing the flexing---not the frame. When any metal bends & twists it get inherently weaker, right ?
This is not true in many cases. Many truck frames (like my Unimog) is riveted together and designed to flex. Even my now gone 2004 F150 frame flexed enough on bad/rough fire roads to potentially destroy a solidly bolted in box/cabin.:coffee:
toylandcruiser
X2 on what 762 said. If the frame is engendered to flex it will not weaken. Skyscrapers are designed to move and flex and they do not fail.
"The right of the people to be secure in their persons, houses, papers, and effects, against unreasonable searches and seizures, shall not be violated, and no Warrants shall issue, but upon probable cause, supported by Oath or affirmation, and particularly describing the place to be searched, and the persons or things to be seized."
toylandcruiser
But if the frame flexes enough to destroy a solidly bolted in box/cabin, it seems like it causes an entirely different set of engineering problems that would not be an issue with a more solid frame?
Such as this:?
https://www.youtube.com/watch?v=_f3CAnH7WIM
https://www.youtube.com/watch?v=bTMcEAiHsn4
That's just failure in engineering.
This is designed to do this and it will do this for the life of the truck with no issue.
zhukoveli
