Annual "CH" Challange rip 2015
Explorer 1
Explorer 1
CH Challenge trip 2015
The “CH” (Cleghorn to Heartbreak Ridge) challenge trip isn’t designed for the faint hearted. It will challenge driver skills, vehicle’s ability and driver and spotters physical and mental endurance. The course driven over two days connects just about every difficult trail from Interstate 15 to Highway 62 in the Morengo Valley. In the two prior runs only 2 vehicles that started made the entire trail and finished the course. For most that come easier “drive around” options are used. Some come and drive a few trails and then leave the course. To the few that complete the entire course belongs the personal satisfaction that they took on everything the trails could throw at them and came through it still standing.
May 2-3, 2105 Saturday & Sunday
The day started with great weather as we met at the Cleghorn trailhead just off the Interstate 15. At the beginning we had the following drivers and vehicles:
1. Me 1990 XJ
2. Matt D. 1987 MJ
3. Fernando G. 1998 ZJ
4. Murrie A. 1998 XJ
5. Michael A. 2014 Tacoma
6. Matt J. 2014 JK
As we headed up the Cleghorn we took all the more difficult options until we came to the “V” notch. Here Murrie, Michael and Matt J. chose to pass around. The “V” notch really tests the articulation on a vehicle.
After the “V” notch there are several challenging hills to climb until we crest the top.
There are a couple of off camber parts and a few steep drops. On one prior “CH” trip one of the guys rolled his XJ on one of the off camber places.
I believe all the group took the more difficult option down. After one of the more difficult drops Murrie noticed his steering acting strange and it was discovered that the high pressure power steering line had a hole in it wand was bleeding fluid with each turn. At this point he had no other option than to exit the Cleghorn on the easy path and make a bee line to Hesperia to find another line then install it. His plans were to only trail with us for the day so it looked like his wheeling might be cut short. So off he went with is twin brother following in his Toyota as support.
On day one, trail one we have already lost two vehicles. It looked like the jeeps would be alone on the trail.
It wasn’t long before we had our second mechanical issue, Fernando’s noticed that one of the bolts that held on his steering dampener had somehow loosened and fallen out. We took a brief stop with enough time for him to remove the other bolt and continue without the dampener.
We completed the last articulation test on the Cleghorn with only Matt in the JK opting out of this challenge.
Once again we hit pavement briefly as we traveled over to trail #2, Pilot Rock which we traveled briefly to what I call the “X” trail (2N17X). There is a brief steep gatekeeper at the beginning of the “X” trail that can intimidate some, but all made it through without any problem. The next serious challenge is what is called the “Middle Lane” trail option. Over the years is option has become increasingly more difficult as the sides have worn into the rut causing the trail in the first section become more of a sand hill climb. About ¾’s of the way up the soil changes and there is a rock ledge that has not worn down so it’s a 2-3’ straight up climb. Last time I drove this I had to use both lockers to get up the ledge. I assumed that it hadn’t changed much and headed up. To my surprise when I came to the ledge my front axle climbed it without too much effort but the next thing I heard was my cross member crashing against the ledge. What had happened over time was as driver’s struggles to get their rear axle up the proceeded to spin their rear tires digging a deeper trough just below the ledge so now it was more like a 3-4’ climb. My wheel base wasn’t long enough so just as my front axle came across the top of the ledge my rear axle fell into the trough. (At this point I reminded myself of the lesson I had told other that they should never assume an obstacle is the same as it was last time and on one as difficult as this, you should take a look at it before you charge up in your vehicle.) After a few tries, I realized that if I were to get over it I had to cock my vehicle sideways some so that the rear wheels could climb one at a time. This would require a rather awkward climb of the trough wall with the passenger side just before the ledge. Hard to describe in words but easy to see when done right. Here is a movie of Matt in his MJ using this technique.
Fernando gave it a try with his ZJ but without lockers and smaller tires the sand was more than he could handle.
Everyone made the rest of the challenges on the “X” trail. Every once in a while we heard from Murrie via 2 meter radio on his progress or lack of it fixing his power steering hose.
We broke for lunch near where we re-joined the Pilot Rock trail and Fernando was once again to work on his ZJ, this time working on the rear suspension.
From here we continued on 2N33 to the Pinnacles Staging area where we started on the Willow Creek trail using the slightly more difficult option, 3N34X. At one of the trail junction Fernando called out on the radio that one of his rear springs had dislodged and he needed to put it back in place. We briefly stopped and after a conference, it was determined that Fern and his ZJ needed some additional attention to be fixed with parts we didn’t have here so he had to bow out of the trip and possibly join up with us at camp tonight if he could get it fixed.
So after traveling on the Willow Creek trail we came to the Dishpan Springs turn off with only me and Matt in his MJ. These happen to be the two oldest vehicles.
Dishpan’s more difficult section can change from year to year. I hadn’t been on this trail for 3 years. The two usual routes had change in that the tougher one (climbing the waterfall) has become more so and the easier (left) route had become so filled with sand that it was easier than prior times.
I had a difficult time once I climb the dry falls in that my spotter didn’t know where my passenger side needed to line up. Without this proper line one risks a roll over by having the driver’s rear tire fall into a deep whole or rut and drag the rest of the vehicle over. You can see what I’m talking about in this movie. If the spotter isn’t familiar with the proper line it is the driver’s responsibility to take the time and instruct him.
After watching me struggle on the water fall Matt chose the easier left route and climbed it with minimum effort.
The balance of Dishpan is a fun trail which we traveled without incident finishing at Crab Flats campground.
We usually stay at Crab Flats to camp on the CH trip but this campground was still closed so our nearest place to camp was 7 miles away at Green Valley Lake campgrounds. It’s an easy ride on a graded dirt road and a small section of pavement to the very small community of Green Valley Lake.
Every so often we could faintly hear Fernando and Murrie talking on the 2 meter radio. It sounded like they were meeting up somewhere on the trail and were trying to make their way to the campground. After selecting a campsite, setting up camp, making a fire and cooking my steak a much clearer call came over my radio from Murrie. He was asking for help, he said that both Fernando and Michael were stuck in rocks on a trail and couldn’t free themselves. He was asking for me to come where they were with my winch and help them out. Knowing the area and the trails I couldn’t imagine where they would be in the route to the campground that would cause them to get stuck. When I asked exactly where they were stuck I got a rather vague answer.
I instructed Murrie to note exactly on the map where they were stuck and then make his way to our campsite where we would discuss and make recovery plans, but first I wanted to finish my dinner. It was about an hour later that Murrie finally showed at the campsite with a description of the trail they were trying to cover when they got stuck. His description sounded a lot like Dishpan Springs but I had serious doubts that the inexperienced drivers with stock or near stock vehicles could make it through that trail. The more he talked the more convinced I became that this was in fact the trail they decided to take and get stuck on. I could hardly believe it.
More later,
Thanks,
Fred
Explorer 1
Explorer 1
Explorer 1
CH Challange Trip part 3
The next day (Sunday) we started early, by this time we had worn out a few of our drivers and vehicles and were down to only three of our original starters.
Jim along with his young son and a friend joined us the night before. They were driving a newer Jeep JK unlimited Rubicon. He wanted to at least do Holcomb Creek and John Bull before he called it quits so he came along for this part.
When we arrived at the initial "gate-keeper" rock garden on Holcomb, I went ahead and drove up through it, parked and then walked back to watch and get a few pictures. I was especially interested in seeing Fernando make his way in his ZJ with open axles.
Behind me came Matt in his Jeep MJ, followed by Jim in his Jeep JK and last Fernando:
By the time I walked back Fernando was just starting into the rock garden. He was having some difficulty when I noticed that neither of his front tires were spinning as he tried to climb the rocks. We verified he was in 4wd and then checked and found that his front drive shaft was turning bit no power to the wheels. Looked like Fern had broken a front CV joint in his Dishpan adventure the day before. So with much reluctance,some help from the others pushing and a hi-jack lifting his rear tires over a rock we were able to get Fern back out on smooth road and get him heading home.
Now we were down to two starters.
Holcomb Creek has several short rock obstacles which require careful tire placement or one can get their axles stuck with their wheels making no contact. On this trail was the only time we came across another group that held us up. A group of Jeeps, TJ's and JK's got one of their party high centered on one of these short rock gardens and had to get pulling assistance to get out. It wasn't a long wait and fortunately we found a spot to get our "group", now only 3 vehicles, aside to let them through.
Here are a few pictures and movies of us on the rest of Holcomb Creek:
After completing Holcomb we headed up the mountain to what was slated our toughest trail of the challenge, John Bull.
More Later,
Thanks,
Fred
Explorer 1
Explorer 1
Explorer 1
CH Challange, Last Part
Wish I had a picture to post of Fernando's front CV joint all in pieces but he hasn't come by the shop to fix it yet, I'm sure it's worthy of mounting on the "wall of shame".
We went directly to the back side of John to run it is what would be considered reverse order. I think this is a little bit easier this way. After a few hundred yards in I stopped as I had lost sight of the two vehicles following and heard on the radio that some metal was getting crunched.
We kept a good pace to the top, where you can look out east over Victorville and Lucerne Valley, for lunch. I was rather pleasantly surprised to not have contact with any other vehicles coming the opposite direction. Unless one of the other drivers has some pictures to give me I have nothing to share until we came out the gate-keeper on the other end.
You can see and hear some banging of the vehicles on the big rock.
For some strange reason at the end of this trail it seems all drivers get out and fall to their knees in thanks and then look under their vehicles. I tried to capture that moment but missed Matt by a few seconds.
We then worked our way out on moderately challenging 3N02 to 3N16. It was here we said good bye to Jim and his gray JK.
Now we were really down to just two vehicles.
Shortly after leaving Jim came to the Gold Mountain trail. Rocky and steep but less challenge than Holcomb and John Bull. It was here we met a group coming up that was planning on doing some trail maintenance. There was just enough space to get on the side and let them around. When we arrive on the wide rock ledge there was an older Jeep YJ trying to get up the right easier side of the ledge with all kind of problems. His engine wasn't running right and his clutch was fairly hot from spinning. I decided, after looking, to drop off about a 3' ledge and go around him. I felt I might hit my sliders but could still pull my vehicle off. I slowly dropped allowing one wheel to slightly lead the other. I must have cleared the edge by a fraction of an inch. Matt then followed but with less lift and a longer wheel base his cross member got hung up pretty good.
Since there wasn't any other vehicle for me to take pictures of I got plenty of these with Matt stuck.
He did finally get free and on his own power too!
Funny story about when Matt was stuck on the ledge on the Gold Mine Trail. The older YJ you can see in one of the pictures was a guy and his girlfriend. You can see the girlfriend out in one of the pictures. The whole time we were there with Matts truck I noticed the girl friend out moving rocks and doing what she could to spot and help her cussing boyfriend get up the ledge. They finally gave up and turned around and went down the mountain about 10 minutes before we got Matt free.
Because we were so low on fuel we came down Gold Mine and drove into town (Big Bear Lake) to the nearest gas station to by some fuel. There in the gas station was the guy with his old YJ standing outside the vehicle talking with a friend. The girlfriend was busy going around the Jeep filling the tires with air. I told Matt this was the kind of girlfriend he needed, one that would do all the work for him as he off roaded!
After filling our tanks and verifying that Matt wanted to continue on the trail we were off to 2N02 to continue the last part of our two day Challenge trip. We made our way over to the Heartbreak Ridge (2N62Y). The Heartbreak Ridge and Pontiac Loop trail are rated as difficult and do have a few challenges but compared to what we had already done this day they were just a steep rocky climb. We stopped for the customary picture at the old Pontiac and proceeded to make the loop and then head down Burns Canyon where we made the high speed run to the finish line and pavement.
We hit pavement in record time with still a few hours of daylight left!
Congratulation to Matt Dillon and the oldest vehicle on the Challenge for completing this tough combination of difficult trails!!!!
Until next time.......
Thanks,
Fred
Explorer 1
pmatusov
AK6PM
Awesome! I wish I was there with you. With one exception - I won't do that hillclimb on 2N17X. Had a bad experience riding a stalled SJ Cherokee backwards from the very top to the very bottom, with a bunch of people and trucks scattered around.
The only thing I'd add is taking Rattlesnake Canyon instead of bailing out in Pioneertown.
Explorer 1
Explorer 1
Thanks, our first CH Challenge was called the "CJ" challenge because we came out Rattlesnake Canyon to Johnson Valley, hence the "J". But because this finished us so far away from home and the drive back through Hesperia was so long, we opted to come out through Pioneer Town.
By the time we reach Burns Canyon we're on the rather haggard side of things.
I hear you on the "X" trail and the Middle option, The time before we had a Toyota Tacoma break one of it's front CV joint trying to make it through. To me it appears to be worse now than ever.
Thanks,
Fred
Explorer 1
4runner168
Wow this is a good challenge you guys deserve KOM trophy for accomplishing this. These trails are tough, especially John Bull.
Appreciate the long write up and report looks fun!
pmatusov
AK6PM
I understand completely :)
I don't think I ever did more than two of these trails back-to-back in one day. Cleghorn and Dishpan, or Dishpan and Holcomb Creek, or Gold Mtn and John Bull, etc.-but no more than two in a day.
Edit - just found the photo I was looking for...
troyboy162
haha yes! We did a "whole bernadino" run a couple years back. You guys took harder trails and did it in less time...I can only imagine how much more tired you were then us. Great pics and thanks for sharing!
Explorer 1
Explorer 1
Nice write up and photos. Your xj looks great explorer1
Thanks, This was the first trip for the XJ since I "restored" it. I also had new engine issues for over 2 years which we finally worked out.
We just repaired the ZJ that had front axle issues on the trail. Here is a picture of it's front spider gears......I guess you could say the trail was a bit rough on them!
Thanks,
Fred
Explorer 1
