Post your Mitsubishi Pajero Pics
Djbenny
A little desert run with my Monty!
katossi
This is my 2002 Montero. I bough it some months ago for $2K (170.000 miles) and since then I did some cosmetic and functional upgrades.
Last trip in Mojave dessert
Right after I installed the rock sliders
Fixes and paint here and there. Ground clearance increased by cutting of some plastics
in Anza-Borrego as I bought it.
Inyo_man
Don't piss down my back and tell me it's raining.
Welcome aboard!
Great to see another white 2002!
Djbenny
Took the Monty out for the first time doing some good wheeling! She did good. I was pleased.
nbishop
97 montero LS acquired
Hi all,
I'm the new owner of 97 Montero LS. It has 93k miles and appears to have been sitting in a barn for a lonnng time. I bought it from some guys who got it at auction and the service records aren't that good. The plan is to check to see if the timing belt has been replaced, replace if necessary, and put in a new radiator as there are a few leaks I can see on the top. The front suspension seems to be sagging a bit and the ride is a little bouncy, so new shocks may be in order. After I get it running reliably, I plan on putting 33x10.50s on the stock rims and building a roof rack using an atv ramp as has been posted around here. Eventually swapping an SR rear axle would be awesome but I probably won't be doing to much crawling in it.
I'm stoked to have a solid 4x4 and a lot of projects lined up!
Djbenny
View attachment 294422View attachment 294423
Hi all,
Congrats! Welcome to the Montero World. I loved my gen 2! Solid vehicle! Any questions don't hesitate to ask. If front end is a little low you may be able to crank the t-bars to raise it up.
Henrybrowne
